the one with the "t" is the power steering fluid reservior, bro
i tried posting a labeled picture of the engine bay but my computer is jus too slow u can search some of threads here and u can still find it |
i filled it with dextron 3 tmf to the top of the cold, but what can this grinding noise be. http://i46.photobucket.com/albums/f1...do/th_this.jpg |
The toyotas use dex3 in the power steering. Keep that filled to the 'hot' line, so you don't run out and ruin the pump or rack. If you find that you need to fill it often, then you will need to find the leaks and fix.
The tranny has a drain plug on the bottom, and a fill plug on the side. Use something like 75w-90 gear oil, or synthetic. The grinding sound is probably a bearing in the trans. If it continues after the oil change, have a 'trusted' tranny shop listen to it and give their opinion/quote$$. Same 2 type plugs on the rear end (diff). I use Amsoil synthetic gear oil, but you can use the same as for tranny. I ALWAYS change all the fluids when I get a vehicle. I want to see how bad the old looks, and know that I am starting out new. If you see a silvery look to the old diff or tranny oil, that is metal, and you might need a rebuild. Although, I have seen many that lasted for several more years with new oil. |
http://www.cygnusx1.net/Supra/Librar...ion=RA&Page=23
part 500 36 49 drain plug and gasket & fill plug, I believe they are the same part # (get new gaskets from toyota first) the fill plug is just above this part 475 34 47 http://www.cygnusx1.net/Supra/Librar...tion=MT&Page=9 parts 410 30 40 |
And yes, fill up till it comes back out, then let drain out fill hole till its about stopped coming out. |
ok it sound e z so will see when i do it. hope there no metal in it
dont wanna jack the thread
is it jus me , cuz on my car it says "TOYODA" instead of toyota or does everybody have this? |
