Old 12-09-2006, 11:41 AM   #1
supraman121
Default engine installtion
installing a 7mgte in a na supra is it hard cause i dont want to spend to much time and money if we have problem's installing the engine is it all the same exept for the turbo and intercooler?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 12-09-2006, 06:06 PM   #2
IHateHacks
IHateHacks's Avatar
One difference I know of is a N/A supra has a distributor and a turbo supra has a cam position sensor so the engine wiring harness will be different. The wiring harness for the turbo coils will be missing from the N/A harness also. Im sure there are other minor differences, I just cant remember because Ive been locked up since July.
Old 12-09-2006, 07:25 PM   #3
supraman121
Locked up?
K&N Air Filter
Old 12-09-2006, 09:53 PM   #4
IHateHacks
IHateHacks's Avatar
As in incarcerated, I just did time in state prison. It was not fun, I missed my supra very much.
Do you have a turbo supra engine harness and ecu?
Old 12-09-2006, 10:01 PM   #5
jfunez
jfunez's Avatar
[QUOTE=IHateHacks]As in incarcerated, I just did time in state prison. QUOTE]
what in the world did you do this time? LOL....
Old 12-10-2006, 12:27 AM   #6
rnoswal
rnoswal's Avatar
I did an automatic to manual tranny swap and if you don't like wiring problems then the engine is going to be ten times harder. I still couldn't get the cruise control to work, so no telling what won't be compatible for the engine swap.
I think It would just be easier to turbo an N/A engine. The compression is a little higher, but nothing out of line for some of the turbo cars of today. Just have to make sure of the timing and fuel.
Good luck
Russ
Old 12-10-2006, 08:11 PM   #7
supraman121
Ya i want to run higher boost then 9psi lol im looking into a "stroker" engine...
seems kind if expensive but the engine needs to be rebuilt and i would much rather rebuild so i can keep all the vid # the same...
http://www.importperformanceparts.ne...s_toyota2.html
kits they up grades the 7mgte and the 7mgt and then im going to look for a "valve train" upgrade
http://www.suprastore.com/enhepa.html
Thats the the 7mgte but im sure they probly fit... and would make my car able to boost a crap load
K&N Air Filter
