Old 12-11-2006, 09:39 PM   #1
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
Question maneul conversion ?s
i am planing to do a transmission swap when i geto ut of school for christams holidays me and my brother are going to put a 5 spd in my 88 supra my question is can i do the swap without pulling out the engine i no it will be hard ot get the bell housing bolts out if u dont pull the eninge but if i didnt have ot pull the enigne it would be a lot faster and easyer and if anybody has donbe this bwefore i was wonder about how hard is it to do and about how many days it takes to do it thanks
Jeff_5_7 is offline   Reply With Quote
Old 12-12-2006, 04:59 AM   #2
kwnate
Yes, you can leave the motor in. Unbolt the trans crossmember and lower it on a jack until you can get at the bellhousing bolts up top. Don't forget the starter.
It can be done in a day if you know what you're doing, take your time. Make sure you have all the parts before you start. Also a good time to replace the rear main seal.
Nate
Old 12-12-2006, 06:32 PM   #3
Jeff_5_7
Jeff_5_7's Avatar
ok thanx i still dont really understand tho it is really hard ot reach the top bolts on the bell housing i no to take aout the crossmeber and the drive shaft but how will that help me get the bell housing lose also how hard is it to but i nthe cluch pedal switch the brake peadl and but in the cluctch masdter cyclinder i heard those are some of the hardest thing to do i would apprecitate the help sincei am only 16 and am wokring on my supra project
Old 12-12-2006, 06:39 PM   #4
Jeff_5_7
Jeff_5_7's Avatar
it there any way to tell if u have a R154 or W58 5 speed tranny
i just ahve a 5 speed an heard these r the only 2 u can do the swap with how do i find out which one i have
Old 12-13-2006, 06:32 PM   #5
Jeff_5_7
Jeff_5_7's Avatar
any one no anything
Old 12-13-2006, 08:02 PM   #6
supraman121
Dont no unless your planning on running like 400 somthing horspower the only thing that really matters is if you have a good clutch for the trans cause the w58 or what ever it is will work with the car but you need to have a nice clutch for it to hold the horsepower from the turbo
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
7MGTE-7MGTEU conversion guide? ravenmaster MKIII Supra 1 02-17-2008 01:17 AM
Flip headlight conversion?!?! dannydavi MKIII Supra 3 03-18-2007 12:25 PM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
celica supra engin conversion supramadness MKII Supra 3 04-10-2006 12:00 AM
