#11 |
can u feel it move into gear when u move the shifter if u cant it just goes throught without moving prob your shiftin linkage if it goes in ot gear and wont move prob your torque converter bolts cmae out and your torque converter isnot hooked up to the flywheel
#12 | |
no i can't feel anything when i move the shifter
my modifications blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs comming: new fly wheeel and not running for sale car parts for sale misc. things for sale Quote:
![]() stole it from sm |
#13 |
sounds actually like the internal seals are broken and the system cant build up pressure, after all its just a Hydrolic system. i had that problem with a transmission and replaces it. bought a JDM transmission online.
but a problem im having now. which i am not understanding. when i start driving will stay in first gear until it warms up a little bit. |
#14 |
It sounds like the infernal pressure disc unit has a glitch in the coupler device. You can fix it by moving the shifter up and down and not pressuring the lifter when you see the red light come on, but your girlfiend should not be looking at it when that happens or it will never go into gear 2 while warming the gearbox up three times and cleaning the filter to let the fluid drain into the lower case box.
If that made any sense to anyone then they should be able to diagnose this transmission problem. I have been working on my cars as a hobby for many years and worked on them as a mechanic a while back and I still can't tell if he is trying to fix a manual transmission, automatic transmission or trying to fix the muffler bearings. Good luck with it. Russ |
#15 | ||
![]() Quote:
#16 |
OK, I guess this question has already been answered, but I missed it somewhere. The mods listed below the question, are they your car or your girlfriends? If it is for the girlfriends car then the Clutch masters FX300 is a waste of money because that is a replacement for a MANUAL transmission.
If it is indeed an automatic transmission then either the filter is clogged, the torque converter is bad or the fluid level is way low or non existent. If the second is the problem then the trans has to come out and if it is out then you might as well ahve a shop look at it. If the first and third is bad then fix those and see what happens. The last thing I can think of is that the linkage is not hooked up and the trans is not being moved into any gears at all and that means crawling under the car to check that part. If you decide to change to a manual tranny, it is possible, I have done it, but you run into some issues in the change that can be annoying. Like the cruise control won't work and the O/D light stays on all the time. Russ |
#17 | |
the list is for my 87 turbo and thanks for the info
Thread Tools | |
Display Modes | |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Auto Tranny Issues? | jbjorndal | MKIII Supra | 3 | 03-14-2008 09:31 AM |
supra auto tranny | wildheart737 | MKIII Supra | 5 | 10-19-2006 01:32 AM |
Difficulty of changing tranny from auto to manual | vas85 | MKIII Supra | 2 | 06-03-2006 08:30 AM |
