Old 12-30-2006, 11:13 PM   #11
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
can u feel it move into gear when u move the shifter if u cant it just goes throught without moving prob your shiftin linkage if it goes in ot gear and wont move prob your torque converter bolts cmae out and your torque converter isnot hooked up to the flywheel
Jeff_5_7 is offline   Reply With Quote
Old 12-30-2006, 11:48 PM   #12
mizuboi
mizuboi is on a distinguished road
no i can't feel anything when i move the shifter
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 01-02-2007, 02:20 AM   #13
Zipakna
Zipakna is on a distinguished road
Default re:
sounds actually like the internal seals are broken and the system cant build up pressure, after all its just a Hydrolic system. i had that problem with a transmission and replaces it. bought a JDM transmission online.
but a problem im having now. which i am not understanding. when i start driving will stay in first gear until it warms up a little bit.
Zipakna is offline   Reply With Quote
Old 01-02-2007, 01:53 PM   #14
rnoswal
rnoswal's Avatar
It sounds like the infernal pressure disc unit has a glitch in the coupler device. You can fix it by moving the shifter up and down and not pressuring the lifter when you see the red light come on, but your girlfiend should not be looking at it when that happens or it will never go into gear 2 while warming the gearbox up three times and cleaning the filter to let the fluid drain into the lower case box.
If that made any sense to anyone then they should be able to diagnose this transmission problem. I have been working on my cars as a hobby for many years and worked on them as a mechanic a while back and I still can't tell if he is trying to fix a manual transmission, automatic transmission or trying to fix the muffler bearings.
Good luck with it.
Russ
Old 01-03-2007, 12:21 AM   #15
mizuboi
Russ
okay for the last time it is an automatic transmission and the problem is that there is no movement in the car when i put it into drive or second gear or first gear and the reverse does not work either
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 01-03-2007, 01:02 PM   #16
rnoswal
rnoswal's Avatar
OK, I guess this question has already been answered, but I missed it somewhere. The mods listed below the question, are they your car or your girlfriends? If it is for the girlfriends car then the Clutch masters FX300 is a waste of money because that is a replacement for a MANUAL transmission.
If it is indeed an automatic transmission then either the filter is clogged, the torque converter is bad or the fluid level is way low or non existent. If the second is the problem then the trans has to come out and if it is out then you might as well ahve a shop look at it. If the first and third is bad then fix those and see what happens.
The last thing I can think of is that the linkage is not hooked up and the trans is not being moved into any gears at all and that means crawling under the car to check that part. If you decide to change to a manual tranny, it is possible, I have done it, but you run into some issues in the change that can be annoying. Like the cruise control won't work and the O/D light stays on all the time.
Russ
Old 01-03-2007, 10:46 PM   #17
mizuboi
the list is for my 87 turbo and thanks for the info
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
supra auto tranny wildheart737 MKIII Supra 5 10-19-2006 01:32 AM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
