-   -   gear shifting problem (http://www.toyota-supra.info/forums/mkiii-supra/7059-gear-shifting-problem.html)
suprascott 12-12-2006 09:42 PM
hey guys, i have a 1988 toyota supra 3l manual, iv had it for 6 months and now have encounted a problem, the other day when driving i found it hard to change into 3rd gear and the same into 4th! i changed the clutch cylinder on the side of the gearbow (cant remember if its the master or slave) 5 months ago because of a leak. the car drives fine now, i pumped the chutch for a few minutes yesterday because i thourght it could of possibly been an airlock (as i top the fluid up every 6 or so weeks). Could that be the problem or is it likely to be something else?
jfunez 12-13-2006 04:10 AM
check the master cylinder....if its wet at the firewall...if not also check under the carpet where the clutch pedal is..if its wet it means it's bad too..
