Old 12-18-2006, 12:34 AM   #1
supraman121
Default tail lights out need help!
Is there a fuse that runs the back tail lights on our cars? I have brake lights when i hit the brakes all the brake lights come on but when i have my head lights on the tails lights are suppost to come on too but mine dont.
Any help would be appreciated.
Thanks in Advance
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 12-18-2006, 01:38 AM   #2
Murd
First check to see if your front marker lights come on. If they don't then check your fuses. If your front marker lights DO come on, check your wires at the back to see if you're getting current to em. Use a test light, they're cheap to get. If you're not getting current at the tail light, but you are getting marker lights up front, you'll basically have to work your way to the front checking the wire to see where the short is. Or to the back if you know where the wire originates from.
Old 12-18-2006, 03:26 PM   #3
supraman121
Well i got marker lights, and brake lights when i hit the brakes but when i turn my lights on your tail lights should glow mine dont glow they only work when i hit the brakes
K&N Air Filter
Old 12-18-2006, 05:51 PM   #4
Murd
If you have marker lights while your head lights are on but not tail lights then you have a wire problem somewhere, like I said before, get a test light. They're under 5 bucks for a cheap one and it'll help you find where the problem is.
Old 12-19-2006, 07:08 PM   #5
89_supra_
89_supra_'s Avatar
89_supra_ is on a distinguished road
ihave an 89 supra and theres a fusebox under the steering wheel kickpanel just look at all of your fuses. im sure theres a few blown. just take them out one by one. and whatever one is blown put a new one in.
89_supra_ is offline   Reply With Quote
Old 12-21-2006, 09:16 PM   #6
supraman121
I did it didn't fix anything, when they rewired my alarm.. i would hit the brake pedal and the gauge lights would come on now they dont so im thinking when they rewired it they messed something up and now they lights dont work
K&N Air Filter
After market tail lights coltskicker MKIII Supra 2 04-19-2008 12:19 AM
Modded Tail lights "JDM look" theWeezL MKIII Supra 15 12-16-2007 12:09 AM
Aftermarket Tail lights?? kewlcoconut MKIII Supra 26 09-09-2006 06:35 PM
