Old 01-01-2007, 10:47 PM   #1
gomezmk
gomezmk is on a distinguished road
I checked all the plugs, coil packs, wires it's all good. It does not miss, it just stops pulling after 5,000 rpm. It does matter whether the motor is in boost or not, it does it also in neutral so that rules out alot of stuff such as ignition wise being faulty or weak. I'm suspecting either an rpm input such as a cps where data at higher speeds is getting corrupted before it inputs to the ecm or the ecm itself being faulty. It seems engine speed input is the source of the problem.
gomezmk is offline   Reply With Quote
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
