Old 12-26-2006, 02:01 AM   #1
gomezmk
Default No high rpm?
I have a problem with my 87 supra that was a na body with a jdm 7mgte installed. For some reason the motor just does not like to rev pass 5,000 rpm, it's just not pulling anymore. I suspect either a bad ecu, or a ignitor. It does it under load and also in neutral(its a 5 speed). I did basically bought everything on ebay to convert it to turbo. The coils ohmed out ok. The afm is ok because I hit fuel cut once and the fuel cut works off the afm. I know for sure I don't have a boost leak. I installed a FCD, I currently running 11 psi.
Old 12-26-2006, 02:12 AM   #2
Isphius
Isphius's Avatar
Check codes!! it is probably a plugged cat though. check that out. Take your oxygen sensor out and drive around and see if its any better.
Old 12-26-2006, 02:23 AM   #3
gomezmk
I have no codes, no cat and why would the oxygen sensor cause anything if the ecu ignores the o2 sensor under wide open throttle.
Old 12-27-2006, 02:13 AM   #4
kwnate
Check your plugs, fuel filter and fuel pump.
Nate
Old 12-27-2006, 01:52 PM   #5
Staceman
Staceman is on a distinguished road
X2, especially the filter / pump.
Staceman is offline   Reply With Quote
Old 12-27-2006, 04:12 PM   #6
justin1642
justin1642's Avatar
if it isn't any of the above possibly the knock sensor that caused power loss and caused my car to run funny before. could be a long shot though. good luck
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
