Old 01-05-2007, 11:39 PM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Default Not Holding Boost
Hello again. I need a little wisdom here. I have a '90 MK3 Turbo. The car is not holding boost. If I accellerate slowly, I get a stuttering or chattering a little above 2lbs. If driven hard, it holds boost. It almost felt like clutch chatter, but it only does it a little into boost at any RPM range. Could it be the wastegate? Stock Turbo, 142000 miles.
abhattan is offline   Reply With Quote
Old 01-06-2007, 03:02 PM   #2
IHateHacks
IHateHacks's Avatar
There's your problem. By the way you are describing it, it sounds like excessive shaft bearing play on that sucker. You can check it by removing the air box/MAF/accordian hose that goes onto the compressor housing (inlet) of the turbo and with your index finger and thumb try wobbling the compressor wheel shaft. The spec is something like .13 mm so any play at all is not good.
Only other way you won't hold boost is a vacuum leak. Try checking the vacuum hose that runs to the wastegate actuator.
Old 01-09-2007, 05:10 AM   #3
drmmr15
drmmr15 is on a distinguished road
How do you get to that hose?
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
Old 01-09-2007, 04:18 PM   #4
IHateHacks
IHateHacks's Avatar
Take off the big rubber hose that goes from your MAF sensor to the compressor housing. We usually call it the accordian hose because it has ribs in it that looks like an accordian. It will be staring you in the face then.
Old 01-10-2007, 05:39 PM   #5
Supra2NR
Supra2NR's Avatar
Does your car makes that sssssshhh sound when it starts to create boost?
I jus got a turboxs boost controller
And overboosting has been the issue
I've been trying to get it a set level
But I have a broken blowoff valve
Which I think is causing my boost level to go ballistic
And I'm not holding boost either
I tried dialing it at 10 psi
But when it gets to 10 it drops back down
Not even holding for a second
Does anybody have a stock bov for sale for cheap?
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
Not holding a boost 88boostr MKIII Supra 12 05-18-2005 02:23 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
