Old 01-06-2007, 07:40 PM   #1
supraman121
Default na engine with 3" exhaust?
would a 3" exhaust increase or decrease the performance of my car? or will it just change around where i have the power? like more top end speed or more low end torqe?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 01-06-2007, 08:04 PM   #2
mr.w
mr.w is on a distinguished road
I'm not to sure but I think it would definatley ruin alot of your low end power and burn up your seals.
mr.w is offline   Reply With Quote
Old 01-06-2007, 08:11 PM   #3
supraman121
What seals would it burn up? It just a exhaust i can see how it would mess with the power but seals?
K&N Air Filter
Old 01-06-2007, 08:19 PM   #4
mr.w
I could be wrong about the seals thing, it just could be a myth a heard. I do know that its not good to run the car without enough back pressure.
Old 01-06-2007, 10:12 PM   #5
marc
it wont kill any power, it will be all performance. im almost 100% sure that the exhaust will only give u positive results. and theres no seals to brun either
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 01-06-2007, 11:54 PM   #6
supraman121
I have been told i will lose low end power cause of the increased exhaust, i mean they put 3" on turbos cause they have more back pressure which means they need a more open exhaust, i wish there were dyno test results or somthing lol if i get mine down i will dyno it before the exhaust and then after see what the results are
K&N Air Filter
Old 01-07-2007, 01:24 AM   #7
mr.w
this might help http
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
Old 01-07-2007, 04:12 AM   #8
sd88supra
sd88supra is on a distinguished road
2.5" is probably the biggest you can go on an n/a to get good results. 3" is way too free-flowing, and yes youll lose low end torque. check out the "Exhaust systems researched" thread in the FAQ.
sd88supra is offline   Reply With Quote
Old 01-07-2007, 12:06 PM   #9
Supra2NR
Supra2NR's Avatar
i agree with him
n/a with a 3" exhaust and youll lose sum bottom end power
ie sum torque
n/a uses the backpressure of the exhaust system to gather up sum torque
have the exhaust too free flowing and loss of hp will occur
idk about top end power
well there's not really that much with the n/a
cuz its starts to slow down at 4th gear
Old 01-07-2007, 04:44 PM   #10
skunk
skunk's Avatar
skunk is on a distinguished road
The only possible damage it could do is (this is rare), when the outside tempeture is cold-- really cold-- the exaust pipe will build condensation. This can travel to your exaust valves. Then when you start the car ---WARP!
But a friend of mine has an N/A with three inch straight pipe and he loves it.
I would not worry about the bottem end power.
Also if you need back pressure and a bend at the end of the pipe when installing.
skunk is offline   Reply With Quote
Exhaust Cloud when Starting Engine Jet Krosswind MKIII Supra 6 09-16-2008 04:54 AM
3" Open Downpipe or 3" Full exhaust? redmaro MKIII Supra 13 09-26-2007 06:49 AM
full 3" turbo back exhaust system frostburn MKIII Supra 0 08-30-2006 09:42 PM
