Old 01-09-2007, 04:46 AM   #1
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Question Start up and engine dies.
Well for about a month or two I've noticed that driving my car around and stopping at a stop light my rpms bog a little while sitting idle, so I rev it a bit higher for a couple seconds and the rpms stabilize. This started to occur more often and lately when I start the car it just dies immediately after. Then I fire it up again and notice the rpms are bogging and I have to rev it up higher to keep it from dying. Then all is fine as if nothing was wrong. About three months ago I replaced the spark plugs and the car was idling perfectly, and until about a month ago this started to happen. Any ideas as to what I should consider replacing? From what I know the fuel pump might be getting a bit old and I'm not sure how old the distributor is.
Drag0na5h is offline   Reply With Quote
Old 01-09-2007, 04:47 AM   #2
burton51m
burton51m's Avatar
spark plugs again. your running rich?
Old 01-09-2007, 04:47 PM   #3
Drag0na5h
Drag0na5h's Avatar
Yeah it seems that way. I was running rich before I put the new sparks in. As soon as I changed them my exhaust smell was perfect, but after this problem came around I noticed a lot more moisture from my exhaust again. I'll take a look at the sparks again to make sure they're all fitted correctly.
Old 01-09-2007, 09:53 PM   #4
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
this was happening to me and when i checked my plugs my #6 had oil in it. replaced valve cover gaskets and problem was fixed. check for oil in plugs
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 01-10-2007, 03:05 AM   #5
1988gte
1988gte is on a distinguished road
Drag0na5h off topic but i love your wheels!!! anyway mine did the same but i have not replaced my sparks yet. got about 200 miles this last tank smells like gas bad and also lots o mostuire maybe bad o2??
1988gte is offline   Reply With Quote
Old 01-10-2007, 09:48 AM   #6
Drag0na5h
Drag0na5h's Avatar
Wierd, but I was driving it around today and the car was actually performing very well. I didn't notice any of the symptoms I reported about earlier, but I will check for any fluid buildup around the spark plugs. Earlier in the Fall my coolant hose leaked right over the entire valve cover/spark plug channel and drenched my spark plugs. That was the reason my spark plugs were replaced. It's possible the installation has become a bit faulty so I'll double check and make sure all is tight and snug. O2 sensor was replaced in the summer.
About the wheels I got em cheap on Ebay. Just had to get that staggered look for the ride. They are 17s (215Front & 255Rear) by the way. (Tires are still affordable at that size.)
Old 01-11-2007, 06:29 AM   #7
1988gte
i guess the black and white just goes good, the ride height looks good to. I think it has to to with the weather (dry 55 low 60's). My car was just fine today no sputter or trying to die, but still has a slight miss at idle, and the gas smell. Hopefully when my plugs and wires come in it will all go away.
Old 01-11-2007, 09:43 PM   #8
grygst76
grygst76 is on a distinguished road
replace the O2 sensor,
89 Turbo, no mods yet
5 speed mbc to 10psi
grygst76 is offline   Reply With Quote
Old 01-12-2007, 02:45 AM   #9
1988gte
well died twice on me today
Does it really affect the car that bad?
Old 01-12-2007, 05:29 AM   #10
damdog05
damdog05's Avatar
have you checked for oil in the plugs yet, cus your car is doing exactly what mine did
My cars:
At Full Engine Warm Up Engine Ildes Down And Sometimes Dies!!! RspecMKiii MKIII Supra 13 11-05-2009 01:56 AM
engine cuts and dies uddinf MKIII Supra 9 09-06-2009 06:56 AM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
Engine still wont start 87 supra 7mge lilsmitty MKIII Supra 12 01-12-2006 10:53 PM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
