Old 01-09-2007, 05:35 AM   #1
nolefan123
nolefan123 is on a distinguished road
Default 2JZ conversion
I have a 86.5 and I was wondering if anyone has done a 7MGE to 2JZ-GTE conversion? How realistic is this and roughly how much would something like this would cost? Or would it be much smarter to swap it to a 1JZ-GTE?
nolefan123 is offline   Reply With Quote
Old 01-09-2007, 09:10 PM   #2
tone loc
tone loc's Avatar
if you want to put in a 2jz its ganna cost 5-6000. not really sure how to do it though. i know you will need a new trans new ecu , engine mounts and couple of other parts.
Old 01-10-2007, 05:33 PM   #3
Supra2NR
Supra2NR's Avatar
Let me ask you a few things
What are your goals for the car?
If your jus looking for a daily driver with a little kick to it do the 1jz swap
But if you're goin for sum power
The 1j is useless since the swap is gonna concern the same things with the 2jz swap
And you wil benefit more from the 2jz in the long run
Money and power wise
I say 2jz will be the better investment for you
Old 01-10-2007, 10:55 PM   #4
nolefan123
Im lookin for something that will handle most of the cars I see around town. But not a full out race car. I appreciate the advice.
Old 01-10-2007, 11:18 PM   #5
supraman121
Was this a qoute for installation as well? cause i thought the 2jz just the engine was like 2k and i dont even now how much the tranny and the ecu cost the new wiring harness and then you got to spend the money to get the old tranny/engine mounting brackets removed and if your 5spd going to six would you not have to replace the clutch? clutch kits for the 2jz are not exactly cheap?
Go for the 7mgte swap fits right in and you can use the orginal tranny for a while and for like 6k you can put better injecters and bigger turbos on the engine have it installed and be pushing nice power to the ground but dont do it on the w58? i think that is the tranny in our 86.5's
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 01-12-2007, 09:58 PM   #6
Fkatz
Fkatz is on a distinguished road
i hope on getting some money together soon in the future and have done alot of studying on the 2jz swap to an 87 supra i planned on buying a bellhousing and clutch setup for around 1000 that i could bolt up to the w58 and put another w58 in the trunk for when it blows up i know that sounds stupid but i dont' want a 6 speed i want to take the car to the track if that is too exspensive look into setups w/gm transmissions you know those are cheap and easy to find.
Fkatz is offline   Reply With Quote
Old 01-12-2007, 10:14 PM   #7
supraman121
What about the 7mgte turbo 5spd tranny? it can hold more power then the w58 and it bolts right up as well
K&N Air Filter
Old 01-13-2007, 01:50 AM   #8
Supra2NR
Supra2NR's Avatar
Default 2grand 2jz
Where can I get a 2jz for 2000
I swear to god point me the way
And I will stop saving up money for parts for my 7mgte
And go straight to the 2j
What company, and does anybody have any experience with them?
Old 01-13-2007, 03:26 AM   #9
Fkatz
where u at in Chicago where u race
call up Sokos 800 338 7656 or 847 451 1400 saw a guy w/ a 240 swap and it ran 13.5 he said cheaper then ebay and no problems or call up this japanesse guy in the yellow pages forgot the name but it is an american name but he's japanesse he's cool i talked to him for an hour on 2jzgte motors he told me alot they even got the vvt i i'm pretty sure he gives u the ecm and he won't charge u for the ignitor chip he said u can run the auto ecm w/out any mods. i'm going to give u a site to go to get 2jz bellhousing u can run to 5 speed transmissions so u don't have to buy the 6spd getrag for however much.
Old 01-13-2007, 03:35 AM   #10
Fkatz
http://www.jspecautosports.com/catal...spx?prod_id=90 never dealt w/these guys but this is a really good price then u dont have to mess around w/ clutch setups and bell housings and the whole nightmare
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
7MGTE-7MGTEU conversion guide? ravenmaster MKIII Supra 1 02-17-2008 01:17 AM
Flip headlight conversion?!?! dannydavi MKIII Supra 3 03-18-2007 12:25 PM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
celica supra engin conversion supramadness MKII Supra 3 04-10-2006 12:00 AM
