Old 01-13-2007, 11:39 PM   #1
2JZEFINI-17
2JZEFINI-17 is on a distinguished road
Angry Power steering pump.. 89 turbo.
My power steering pump was making noise and the wheel was getting hard to turn, so I decided to replace it. I bought one of of ebay from a user with a pos feedback of 99.9%. I pulled the old pump out and installed the new one(which may I say is the biggest pain in the ASS!!!). I filled it up with PS fluid, left the cap open while the car was running and turned the wheel left and right to bleed any bubbles out the system. The new power steering pump also makes noise! Is there anything I can do or is this pump also bad??
2JZEFINI-17 is offline   Reply With Quote
Old 01-14-2007, 07:02 AM   #2
mrnickleye
mrnickleye's Avatar
Thumbs up Additive should help
Oh, all right, I'll tell you what I know.
Many pumps make noise, sort of a buzz, or whine. It may increase when turning the wheel.
I've had more than one "reman" pump make a lot of noise. So much so, that I had to replace it under warranty.
Ford pumps make noise more than any other brand.
Toyota pumps aren't known to be noisy. Was the ebay one a used one, or rebuilt??
One reason I tell people to buy from a local parts house is the warranty. You can just return it for another one.
Also, I don't buy rebuilt stuff from Pepboys or Autozone, because they sell the cheapest crap they can get.
So what if it is warrantied for life, I just can't afford to keep using that warranty.
You can try to quiet the pump down by adding a cup of LSD additive from BG (sold thru repair shops)
BG LSII
Limited Slip Axle Additive Concentrate
BG LSII is designed to prevent chatter in plate and clutch type limited slip differentials. BG LSII may be used with any GL-5 gear lubricant in limited slip applications. It is also excellent for eliminating chatter in full-time four wheel drive transfer cases. The ingredients in BG LSII smooth and quiet operation of gears in the differential and fortify the additives in the gear lubricant.
Part No. 328
6 oz. (177 mL) tube
or some Ford LSD additive (get at dealer).
If it won't quiet up with one of those, it ain't gonna get quiet.
Old 03-13-2007, 02:56 AM   #3
drmmr15
drmmr15 is on a distinguished road
Sorry about the bump, but I am in the middle of replacing my PS pump, and cant seem to get if off. 2JZEFENI-17, can you give me any advice on pulling out and installing a power steering pump? Thanks.
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
Old 03-13-2007, 02:59 AM   #4
marc
u sure its not ur rack making noise? i had to replace mine because it wuld leak and get hard to turn and make sum ugly noises.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 03-13-2007, 03:23 AM   #5
drmmr15
I really really really hope its not my rack. It does not really get that hard to turn, but it does make ugly noises when turning. I know my pump has a leak, so I need to replace it anyways. How would I know if the rack was bad?
1987 Supra Turbo
GReddy TT
Power Steering Pump Whining Chambers MKIII Supra 10 01-28-2010 07:19 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
