ok i just bought a a/f ratio guage and boost guage and i am planning on buying a manual boost controller to raise boost to 10 psi. i just want to make sure that it is safe with stock injectors.
my mods: 3in turbo back exhaust (no cats) cooleeze accordian replacement pipe blitz bov cooleeze radiator hard pipe lexus afm (not on don't have 550 injectors yet) engine has less than 100k on it since swap so with all that just want to make sure i can do this with no problems. thanks |
U should be good with that
U even got more mods than me All I got is a simple cone air Intake Still got the stock exhaust piping Stock ic piping Stock injectors But I'm gonna get a full 3 inch turboback exhaust New pump And a afc U should be good for 10 psi with ur mods
ok thanks for the info i'm gonna go get one now
You should be over 10 psi with the 3 inch exhaust and no cats, and if your not, you have a boost leak somewhere. You shouldnt even need a boost controller with that stuff. And your probably pushing your stock injectors at about 12-14 psi. The stocks will run to fuel cut fine, So your limiting factor is going to be fuel cut off untill you get the lex afm/550s in and you probably still wont need a boost controller then. lol.
Yay the supra assistant is gone!!! WEEE!! Last edited by Isphius; 01-16-2007 at 05:53 PM. |
where did u get that accordian pipe? it looks f-in sick.
![]() nothing but the best -mods- so far K&N intake fipk 3" megan downpipe 3"turbo elbow 4 washers on the wastegate highflow cat short shifter 89+ front bumper, pic soon to come many more upgrades soon |
#6 |
They are sold by cooleze. They sell a lot of nice turbo supra parts but there so god dam expensive, So i cant afford them.
Yay the supra assistant is gone!!! WEEE!! |
manual boost controller | tak2099 | MKIII Supra | 5 | 11-23-2009 11:47 PM |
Manual Boost Controller and Turbo timmer question | ethan12510 | MKIII Supra | 5 | 02-20-2008 10:54 PM |
ANY ONE EVERY USE A Apexi Boost Controller | donutking | MKIII Supra | 1 | 10-07-2005 01:58 PM |
installing manual boost controller 1989?? | hamburgler | MKIII Supra | 4 | 07-13-2005 12:55 PM |
