Old 01-25-2007, 04:52 AM   #1
mrnickleye
mrnickleye's Avatar
Yea...the Toyota dealer techs just aren't experienced with MKIII's. They are old cars. Those guys only work on cars about 1-10 years old.
An experienced tech at an electrical shop should be able to figure things out.
He will understand the systems, and the wiring diagrams.
You might be able to find a shop in town that specializes in Toyotas.
Old 01-25-2007, 06:55 AM   #2
stevanom
stevanom is on a distinguished road
Smile
any idea of how I should describe the prob? Is what I wrote in the beginning making sense?
stevanom is offline   Reply With Quote
Old 01-25-2007, 07:00 AM   #3
mrnickleye
mrnickleye's Avatar
Yes, your first post makes sense. It seems you had a major voltage spike, that wiped things out.
Old 01-25-2007, 05:25 PM   #4
SupraDupra
SupraDupra's Avatar
Sounds like your voltage regulator isn't cutting the alternator off when it has enough power.Since the alternator is constantly producing power at a rate greater than your using it ,that little component would be my first suspect.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 01-26-2007, 06:26 AM   #5
mrnickleye
mrnickleye's Avatar
Talking Cheap shit. rebuilds
And the regulator is built into the alternator.
Have the new rebuilt one checked out. It been my experience (more years than I care to say), that about 1 out 10 rebuilt alternators will be bad right out of the box. And...3 more outa the good ones put on will fail withing 3 years.
Lifetime warranty don't mean a thing when you have to use it several times, or the thing fails when you are deep in the middle of nowhere.
But... new one from Toyota will cost you your first born male child, (and a taco).
Cold Start System Testing (hard starting) mrnickleye MKIII Supra 12 11-13-2010 08:32 PM
I've got no EGR system rinso MKIII Supra 6 02-12-2009 08:36 AM
high pressure in cooling system jarekt Non-Generation Specific Questions 3 09-01-2007 06:39 PM
Cold Air system? Black'88 Non-Generation Specific Questions 10 04-22-2006 02:40 AM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
