Old 02-02-2007, 06:46 PM   #1
supra_91
supra_91's Avatar
Default shifting prob
i live in illinois and it is pretty cold here right now and for the past couple of weeks i have noticed that my car won't shift out of first gear when the engine is cold. it finally shifts about 30 secs to a min later but i don't know what is wrong. i have also dropped in gas mileage to getting roughly 200 miles per tank of gas
Old 02-02-2007, 08:12 PM   #2
burton51m
burton51m's Avatar
mine did that a couple months ago. take your car in to a Meineke or somewhere elese and get your transmission system flushed out, and some new tranny fluid put in. after a while it will shift smooth and you shouldnt have a problem.
Old 02-03-2007, 03:15 AM   #3
mrnickleye
mrnickleye's Avatar
^^^^ Yes, the first step is to flush the trans. Make sure you take it to a shop that uses the machine to do it. Not just drain and fill, as that will only get 2 1/2 qts. out.
The machine method cleans insides with a mild chemical then removes all the old oil, and reloads with all new oil.
Old 02-03-2007, 06:23 PM   #4
supra_91
supra_91's Avatar
after i get the fluid changed will it effect the bad gas mileage
Old 02-06-2007, 05:42 PM   #5
supra_91
supra_91's Avatar
what about the gas mileage
Old 02-07-2007, 03:41 AM   #6
mrnickleye
mrnickleye's Avatar
I seriously doubt it will effect the MPG. That is more an engine running condition relationship.
Shifting Issues (Automatic) btwilson86 MKIII Supra 4 11-03-2007 07:05 AM
Hard Shifting in Automatic. redmaro MKIII Supra 2 05-18-2007 04:08 AM
shifting problems 88_supra MKIII Supra 7 03-16-2007 10:46 AM
Manual Shifting Trouble KingJames224 Non-Generation Specific Questions 3 10-22-2005 09:26 PM
Question Regarding Shifting Problems SardonicScotsman Non-Generation Specific Questions 2 08-09-2005 03:38 PM
