Old 05-19-2012, 09:43 PM   #1
wishgirl10
wishgirl10's Avatar
wishgirl10 is on a distinguished road
Default Brake problems
Hi everybody. I'm new to this forum and I'm looking for some help. I have an 86 supra that my boyfriend has rebuilt the engine on (it had a rusted cylinder) and now it's finally running. The biggest problem right now is that the brake pedal is super soft. He's already bled the brake lines and gotten a lot of air out of the lines and he's rebuilt the back brakes because they weren't pushing out before, but now that's fixed and back on the car and the pedal is still super soft. There's enough brake fluid and everything in it. So what we're wondering now is if there's some kind of air bleeder box somewhere on the car (other than the bleeder valves on the calipers). Anyone have any information or ideas?
wishgirl10 is offline   Reply With Quote
Old 05-20-2012, 06:03 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Welcome to the forum!
Although air in the lines is one of the more common problems, another cause of a really spongy feeling brake pedal is a bad brake master cylinder. It should be inexpensive to rebuild or replace, just be sure you bench bleed the cylinder prior to installation.
Old 05-20-2012, 01:47 PM   #3
Green7mgte
Supra Forum Moderator
agreed.. the brake master cylinder can be thought of as a large plunger with a few rubber rings around it.. If not used for a long while those rings dry out, crack or don't hold seal properly. When you go to bleed them they fail and your left w/o brakes.. Thats why some mechanics, while bleeding the brakes, place a block of wood under the break peddle. To stop the peddle from hitting the floor and pushing the plunger in the BMC to its furthest position, if it hasn't been done for a very long time.
Happened to me.. put on a new BMC and that should solve you're problem. If you had a leaky caliper or something, you would see signs of it on your rims. If you had a leaky line some place. probably see it on the garage floor.
Indeed on bench bleeding. here's my thread on me bumbling my way through it..http://www.toyota-supra.info/forums/...-brakes-2.html
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-20-2012, 09:53 PM   #4
wishgirl10
wishgirl10's Avatar
Ok, thanks for the info guys. Very helpful.
Any ideas where we can find a master cylinder rebuild kit? Autozone only has the replacement master cylinder, which we'll get if we have to, but we're trying to save $.
Old 05-21-2012, 12:19 PM   #5
Green7mgte
supra and save money.. you're in the wrong car! lol..
check ebay id imagion.. good luck =)
Supra FAQ
Supra MKIII FAQ
Old 05-21-2012, 03:44 PM   #6
Call around. Napa usually has rebuild kits for things that other stores don't.
Old 05-21-2012, 04:29 PM   #7
Green7mgte
that is a very good point.. Napa can usually get their hands on odd ball stuff..but for a price. I know I can go to my local autozone and get any sort of gasket I need.. but napa will fly me in the actual part if I cant find it anyplace else. Strange how that works.
Supra FAQ
Supra MKIII FAQ
Tags
bleed, brakes, pedal, problem, soft
Brake light problems corytebeau MKIII Supra 6 11-19-2011 04:54 PM
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
Brake light switch and neutral safety switch problems jtown125 MKIII Supra 26 05-02-2010 04:22 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
brake problems gomezmk MKIII Supra 1 09-11-2006 06:13 AM
