k, just as the title says basically. before i say anything, i want to apologize if my main question has already been asked (it probably has), but i want to be as CLEAR AS POSSIBLE on this supra as i love skylines and supras, and want to take care of this for as long as possible.
saw it today, great shape, yadda yadda, rebuilt (or new, i forgot) engine with 100k miles on it, 7mgte engine with ct27 turbo (steel, not ceramic). the only thing worrying me is the head gasket problem. my dad flipped out when i mentioned possibly bad headgaskets, because you have to rip the entire engine apart apparently. from what ive read, the block is iron and the head is aluminum, and electrolysis will slowly wear it away, the iron will degrade, etc. once i found out if the headgaskets are in good working condition or if they got replaced, ill go from there. but lets assume they ahvent. first, what should i buy to replace the problematic headgaskets? ive heard steel headgaskets and ARP studs, correct me if im wrong. secondly, how much will that ring up to? id rather not spend 2 or 3 grand on the car right off the bat, but if i need to ill put that into consideration. thank you very much for any input, i appreciate it greatly! i should have the supra in my hands in 2 to 3 weeks ![]() edit: the headgaskets, at this moment, are fine. the car runs immaculate. i just dont want a HG problem in the future, and would like to avoid the trouble. |
If you are going to do the replacement right away it wouldnt be a bad idea either way. No matter how many miles the engine has on it. If its a stock hg, and the head bolts were torqed to fsm standards it could blow under randomness situations. BUT if the head bolts were torqed a little above fsm standards, say around 80ftlbs than i wouldnt worry about it if your running stock boost with no mods. But if you plan on changing it out heres what i recommend.
ARP Head studs 105.00$ @ https://935motorsports.com/catalog/p...oducts_id=1022 Cometic 2mm Steel Multi-Layer 169.00$ @ https://935motorsports.com/catalog/p...roducts_id=767 That would be a good setup. Then of coarse new gaskets for the things you end up doing in the process (Intake, exhaust, turbo-manifold etc.). Total part will probably run you around 350$ or so. IF your doing the job yourself. My good friend whos a mechanic said the standard time for the 7m by shop standards is rated at about 12 hours labor. Depending on the shops labor charges, could be as much as 1000$ in labor to as little as 700$. All in all its not costing you more than 1500$ tops to get the headgasket redone with a hg that will sustain 30psi all day long. Now say the hg is already blown. Then were talking about pulling the engine and sending the block and head out to a machine shop and get then resurfaced. Prices on that are grey area. Just hope its not already blown basically. Good Luck! *EDIT* The 7m is a I-6, not a v6 as alot of people commonly confuse it, thus there only being (1) headgasket. Last edited by Kuban; 02-04-2007 at 09:19 PM. |
#3 | |
![]() Quote:
so the only problem with the heads is that they werent torqued to a high enough level? or is there something else as well? theres already some mods on it. the newer CT27 turbo, a CAI and a performance exhaust (not sure what size) is going on soon, since theres no muffler and hes just fixing the whole thing. ill have to drive it super careful and resist the urge to floor it :-X |
"Total part will probably run you around 350$"
Incorrect. That will cover the machine work on the head, the head gasket itself and head bolts. And yes, heads should always be sent to a machine shop regardless of what you think. You then need a turbo gasket set which you can only get at the dealer and is $95. You need intake manifold and intake chamber gaskets, fuel injector insulators, grommets and O-rings, copper sealing washers for the fuel rail, fuel line, and turbo oil feed, exhaust manifold gasket, EGR cooler and EGR valve gaskets, etc..... If you look at my BHG post I have a detailed list of all the parts that are needed to repair a head gasket and the prices. The price is more like $700 and thats with a stock head gasket. Metal head gaskets are easily $200 themselves. I paid $99+ shipping for ARP head bolts. Be prepared for extensive labor if you do it yourself, 20 year old gaskets don't just peel off. You better have the tools or a hook up for the tools or that bill will easily add up to $500 itself. |
#5 | |
![]() Quote:
im definitely not going to be able to do it myself, so im gonna have to send it into a mechanic that i know. ill have to specify ARP studs (better than bolts if i remember correctly?) and that special head that was in the second post of this topic. this isnt looking good ![]() |
#6 |
You don't need a metal head gasket if you're going to be running stock boost or slightly over stock. Just make sure it's torqued to 70-80ft/lbs. If you're not getting the block lapped you're probably better off NOT getting a metal head gasket as well... Both surfaces need to be extremely smooth to use a metal one. Get a stock head gasket kit from toyota, it should have all the parts you need in it, grommets and all. I'd suggest still taking the head to a machine shop however.
1989 N/A Targa 5spd. Metallic Grey, w/grey interior. No mods done. |
#7 | |
![]() Quote:
#8 |
"Especially the turbo gasket being metal, depending on condition is very reusable"
No they are not. Why don't you read the TSRM before you start making things up. "My family owns a machine shop, thus rendering that cost useless." Oh thats right, everyone owns a machine shop so no one has to pay for machine work. Plus normal machine work only costs $100 anyways. I had extra work done which came to $200. That still leaves $500 in PARTS not $350. Oh wait, you reuse all the gaskets, yeah thats smart. Have you replaced a head gasket on a turbo 87-92 supra before? I didn't think so. No professional automotive technician reuses any gasket. In the automotive field we call people who do that Hacks. |
#9 |
ill have the money in 3 weeks, ill keep everyone updated because i have nowhere else to spill out my excitement :-D
oh, and my amazing luck continues. he got rear ended yesterday and some stuff is broken\bent, so hes gotta get that fixed. yay insurance. gah. |
1987 Toyota Supra MKIII 350 Chevy / 700R4 Project Car | Vacationtime247 | Show n Tell | 4 | 06-04-2009 03:53 AM |
Looking for the best intake for a 1987 toyota supra non turbo | toofast4urass | MKIII Supra | 6 | 02-23-2007 05:30 AM |
