#1 |
I was doing some researchin the head gasket department and i found a copper gasket with layers of rubber on it to help seal. I was wondering if anyone has heard of these. ( http://www.flatoutgroup.com/gaskets/gaskets.asp ) i have neither the time nor the money to get both the head and block lapped so thought this might help if I only got the head machined. It says they are supposed to help seal everything??? I was also wondering if the copper could hold up to the heat. It says that it can withstand drag car temps... I am somewhat of a supra n00b so dont bash me.
edit: they are metal with the rubber coating... not copper. I still wonder if it will work without the block being lapped?
88 mkIII, manual, turbo, hks valve management system, non restrictive exhaust, cold air intake, 15lbs, 12.89 @108 mph Last edited by mkIIIdraper; 02-07-2007 at 11:58 PM. |
#2 |
Without knowing much about their compound and not being an engineer ,my unprofessional opinion would be to shy away from them.I could be wrong but that just doesn't give me a warm fuzzy feeling.
As for decking the block/head ,are you sure you even need to perform this task? Have you checked the surfaces with a straight edge or anything? It's not always the default nessecity.Another thing to keep in mind is any machining you do will affect the timing ,even if just a tiny bit. Just my 2 cents...
1988 Supra - N/A 5 speed 1974 'Cuda - 318 2001 Cherokee |
#3 |
I have not gotten that far in the process yet i'm just at the point where i'm worried i'm pretty sure i'll have to do the Head gasket replacement though. sorry if i'm a little inexperienced i'm kinda a n00b. Also I've changed my mind about what type of gasket i'll get. I'll probably get a MLS possably by "cometic"
88 mkIII, manual, turbo, hks valve management system, non restrictive exhaust, cold air intake, 15lbs, 12.89 @108 mph |
#4 |
http://www.toyota-supra.info/forums/...ead.php?t=6206
I used this MLS ....for my N/A with a slightly milled head. Ishino is what Toyota used OEM, but now improved design for better sealing, and BHG control. I spent hrs on the net researching supra headgaskets. Mine is N/A with only slight mods. I wanted to do the best job I could to never have a BHG again. Almost 2 years later, and daily 'hotrod' driving, no troubles. http://replacement.speedyperformance...l=null&dp=true Don't just throw a gasket on there. Take the head to a good machine shop and have it checked for warpage & cracks, a valve job, touch up milling and valve lash adjustment. Mine was $450.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. Last edited by mrnickleye; 02-09-2007 at 06:47 AM. |
Thread Tools | |
Display Modes | |
valve cover gaskets are leaking | D_Train | MKIII Supra | 18 | 03-19-2015 04:53 PM |
88 Turbo Leaking Valve Cover Gaskets | Sheridan | MKIII Supra | 1 | 11-05-2007 01:03 AM |
types of gaskets? | brandonsupra | MKIII Supra | 7 | 01-23-2007 03:31 PM |
gaskets | cooley346 | MKII Supra | 2 | 02-28-2006 06:19 AM |
