Old 02-08-2007, 07:48 PM   #1
Jjona5
Jjona5 is on a distinguished road
Default change oil pump without pulling engine
I have a 1988 non turbo 5 speed supra and it used to be a buddy of mine and we rebuilt the engine but the owner didnt replace the oil pump during the rebuild. Now that the car is mine I'd like to do this right and replace the oil pump as well. So is this possible or do I need to pull the engine?
Jjona5 is offline   Reply With Quote
Old 02-09-2007, 07:52 AM   #2
SupraDupra
SupraDupra's Avatar
If you can manage to get the oil pan off the rest would be very do-able.If you unbolted the engine mounts and raised the engine that would be the only way.Not sure if that would give you enough clearance ,but that's about your only option to look into.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 02-11-2007, 03:29 AM   #3
IHateHacks
IHateHacks's Avatar
"If you unbolted the engine mounts and raised the engine that would be the only way.Not sure if that would give you enough clearance ,but that's about your only option to look into."
Nope totally wrong.
To remove the oil pan with the engine in place you must support the engine from above and remove the front suspension crossmember. There are 2 bolts near the rear and 4 nuts up front. You also must remove the sway bar end links. Unbolt the struts from the body. And then the obvious stuff like the exhaust front pipe and stiffener plates.
Look at the TSRM LU-5 to LU-12 if you don't believe me.
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Pulling Engine and trans adamh88 MKIII Supra 3 01-15-2007 05:36 PM
Engine Change nelly26 MKIII Supra 4 10-11-2006 04:48 PM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
1JZ-GTE Engine with 7mge Stock Fuel Pump joolhamdi MKIII Supra 1 06-10-2006 10:29 AM
