think i have a serious problem, my turbo and my turbo manifold is glowing red hot. its never done this before and i also have not downpipe on it, my exhaust stops at the elbow. what could be causing this problem? any help will be greatly apreciated. i checked my timing and it was way off and my afm also went caput today if i plug in the afm it idles and then dies, unplugg the afm and it idles.
#2 | |
![]() Quote:
89 Turbo, no mods yet 5 speed mbc to 10psi |
i have another afm on the way right as we speak its in the mail. my timing was actually below 0. dont ask me how this happened i dont know i set it right last time. and if my afm is bad wouldnt that make me run rich.
Any codes? If the AFM is faulty, then it is probably giving the computer the wrong information. It doesn't necissarily have to go into limp mode.
generally when the afm is faulty it will throw codes
try putting the downpipe back on, just to the cat and see if theres any change then get back to us
#6 |
"my turbo and my turbo manifold is glowing red hot"
The exhaust manifold is most likely warped by now. Warpage limits for turbo exhaust manifolds are .0197 in. Did you set BASE ignition timing? This is done by disabling the electronic advance. Base ignition timing for a turbo 87 should be 10 degrees before top dead center (BTDC). |
Audio and a lot of other things wrong with car | bluemeate | MKIII Supra | 4 | 05-18-2010 07:07 PM |
My fenders look wrong | Kristian_Wraae | Non-Generation Specific Questions | 14 | 05-07-2007 03:20 PM |
New here, quick question on possible lean issue | adamsbomb | MKIII Supra | 6 | 02-13-2007 04:42 PM |
Stock Block | Evilfurby | MKIV Supra | 56 | 01-09-2006 02:23 AM |
