Old 02-09-2007, 09:15 PM   #1
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
Default Gauge Lights
I know I saw a post like this on here awhile back but cant find it. Any way, my gauge lights they dont work at all. When I turn on my lights, my gauges don't illuminate. Also when I turn on my lights if my ac/heat is on the the lights on that unit turn off. Ive turned the dimmer switch both ways and nothing. Its been like this since I owned the car.
OmeGa is offline   Reply With Quote
Old 02-09-2007, 09:25 PM   #2
Supra2NR
Supra2NR's Avatar
Try checking the fuses first
Or maybe sum of the wires are touching a metal part of the car or or it is being pinched
If all else fails
Check sogi, they have a write up on replacing the dashlights
Its pretty simple
Jus make sure to keep track of all of the screws, ziplock bags helpd out a lot
Old 02-10-2007, 07:49 AM   #3
mrnickleye
mrnickleye's Avatar
Best thing (I use) for keeping screws seperated, and from getting lost.......big speaker magnet and metal muffin tray.
Those lights in the heater switches can be a problem. I think they are LEDs. Some of mine have acted up, since I've owned the car for 4.5 yrs. I live with it, cause I don't drive much at night.
Old 02-10-2007, 09:42 PM   #4
kwnate
SP58GT
Your dimmer switch could be bad. Find a good one off a local car and try it out. I doubt that all of your cluster lights took a dump at the same time.
Nate
Old 02-10-2007, 10:49 PM   #5
mrnickleye
mrnickleye's Avatar
Page BE-28 in TSRM
WD-21 Wiring diagram
LF: Lightbulbs guide lamw001 MKIV Supra 2 09-18-2008 02:23 PM
Brake lights not working! lifesnotfair MKIII Supra 18 05-05-2008 11:40 PM
tail lights out need help! supraman121 MKIII Supra 5 12-21-2006 09:16 PM
