I have Heard about a couple of stroker kits you can buy for the 2jzgte. one from 3ltr to 3.4ltr and one from 3ltr to 3.8ltr. I have searched for info on a kit for the 1jzgte but have had no luck. both engines use the same block so i was wondering if someone knows if you could use the 2jzgte kit or if there's a separate kit. If not aparently the 1.5jzgte mod would be the way to go...?
in my opinion
i would go for the 1.5jz... way more torque and power just by bolting them together... i'm not sure if there are stroker kits out there but yea go 1.5 ;) |
Do you know the comparrative hp and torque figures between the 1jz and 1.5jz?
well i could probably get some figures but dont have them here
the quest 4 corona used to use a 1jz then changed to a 1.5.. they mentioned getting a 100kw increase but i will find out for definite... you know what hearsay is like hehe |
Yeah, better start saving some pennies me thinks :)
think 2jz power outputs..but with even better flow over the 2jz head..hence even more power :D . smoother, torq monster, and lots of power :D :D :D
