i just checked for codes and i am getting 13, 24, 31, 51. the car is idling really bad, i checked timing and its right. and i cant drive it it wont go above 2000rpm while moving, but can eventually make it that high while at a stop. its an 87 turbo 5spd. any advice willl be greatly appreciated.
Not sure about the errorr codes but it sounds like you have a massive boost leak. Check your intercooler hoses and clamps.
Could be a clogged Cat also. Mine was clogged, and I had no boost, and wouldnt go above 4500RPM.
1987 Supra Turbo GReddy TT Open Element Filter (<---not sure what brand) YAY BOOST!!!!....finally... ![]() |
give this link a try and it should tell you atleast a bit about the codes.
http://cygnusx1.net/Supra/TechTips/e...ror_codes.aspx
Dan http://www.cardomain.com/ride/2200872 1987 Toyota Supra Turbo Targa, 5 speed, Light blue, 67K miles, MKIV TT polished wheels |
check your tps too. a mal adjusted or bad tps will give you idle problems. thats your code 51.
Audio and a lot of other things wrong with car | bluemeate | MKIII Supra | 4 | 05-18-2010 07:07 PM |
My fenders look wrong | Kristian_Wraae | Non-Generation Specific Questions | 14 | 05-07-2007 03:20 PM |
intake manifold has coolant what did i do wrong? | 91toy supra | MKIII Supra | 6 | 09-16-2006 02:46 PM |
Stock Block | Evilfurby | MKIV Supra | 56 | 01-09-2006 02:23 AM |
