Old 02-20-2007, 10:51 PM   #11
west_side_supra
west_side_supra's Avatar
mine grinds into reverse all the time and i got a stage 3 6 puck clutch, i havent found a good way of doing it i just be patient and it will eventually make it into gear
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 02-21-2007, 01:42 AM   #12
volto
volto's Avatar
volto is on a distinguished road
Mine (86.5) and my brother's (88) do the same thing, I found that if i just put it in fourth, let the clutch out a little bit (make the rpm drop a little), push the clutch back in, and then it goes into reverse no problem , no grinding. It's become a habit to me, i even do it on other cars now. I hope im not causing extra wear and tear on the pressure plate by doing that, but it does work and its easy enough to become a habit.
volto is offline   Reply With Quote
Old 03-04-2007, 09:51 PM   #13
sportriderseattle
sportriderseattle's Avatar
sportriderseattle is on a distinguished road
am I missing something here???? As far as I know, every car or truck that I have driven in the past 25 years, including brand new cars while I worked at car dealerships, there is not one car with manual transmission that will not grind at times when you put it into reverse. It's as common as the turn indicator on a car not turning itself off while making a lane change on the freeway. There is no solution, just accept it, put the car in any forward gear, pull the clutch out enough to move the car forward an inch then go back into reverse.
Dan
http://www.cardomain.com/ride/2200872
1987 Toyota Supra Turbo Targa, 5 speed, Light blue, 67K miles, MKIV TT polished wheels
sportriderseattle is offline   Reply With Quote
Old 12-16-2007, 04:51 PM   #14
Burn N' Up
Burn N' Up's Avatar
The reason you grind gears in reverse is because the tranny is still spinning. come to a complete stop, Push in clutch, place in 1-5(to stop movement), then into reverse. If it still grinds then your pilot bearing is sticking or the clutch isn't fully releasing the clutch plate for whatever reason. Reverse is unsynchronized because the gear it's self doesn't move unless engaged. So if your having trouble pushing it in and it's not grinding then usually a little roll forward or just letting the clutch out and depressing it again will get the gear teeth to line up. Reverse doesn't have a helical cut, it's square and it isn't constantly meshed like your other gears are.
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
Old 12-16-2007, 07:46 PM   #15
CyFi6
Ive just made a habbit of shifting into first and then into reverse everytime, and make sure youre at a complete stop. If you still have grinds then bleed your clutch line and adjust your engagement height.
When you go to put it in reverse and it doesnt go, its just because the teeth on the gear arent lined up and they wont mesh, they have a cone shape to them from the factory which helps it mesh but the more you grind the more those round off. If it doesnt go in when i push at reverse i just slowwwly let the clutch out as if im ready to drive in reverse and it slips in right as the clutch begins to engage and then youre on your way.
Old 12-17-2007, 04:44 PM   #16
OfnaRcR
OfnaRcR is on a distinguished road
Go 2nd then reverse.
OfnaRcR is offline   Reply With Quote
Old 03-15-2008, 07:46 PM   #17
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
Me too I just shift into 1st move the car about a inch and then It slides right into reverse. If I dont it doesn't grind but it just wont go into gear. The w58 does not have a syncro for reverse.
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
shaking in reverse..at low revs??? cel Non-Generation Specific Questions 0 12-05-2008 06:38 PM
second gear grind tak2099 MKIII Supra 10 05-12-2008 03:32 AM
reverse probs? 89_supra_ MKIII Supra 1 12-14-2006 08:37 PM
Manual Shifting Trouble KingJames224 Non-Generation Specific Questions 3 10-22-2005 09:26 PM
reverse glow gauges Stuba MKIII Supra 3 09-23-2005 01:18 PM
