Old 02-20-2007, 08:44 PM   #1
SideWinderGX
Default getting new spark plugs hopefully...heat ranges?!?
k, test driving the 87 supra tomorrow then hopefully buying it on saturday. im obsessed with this car (probably not a good thing. i dreamt about driving it last night -.-) and was thinking about what i should buy first to make sure it runs great. obviously the headgasket problem will be sorted out very soon, it hasnt been done yet. HKS 1.2 mm gasket and arp studs, if i remember correctly (its in my other topic, ill look back again). but anyways, ive settled on some silicon hoses to replace the rubber ones for look and performance, and spark plugs.
iridium seems to be the way to go, but whats all this heat range stuff? im so confused haha. japanese plugs go up and american heat ranges go down, and you go down another level per ~85 HP, i dont know. could anyone explain this in lamens terms and tell me which are a great plug to buy? thanks haha
Old 02-20-2007, 10:51 PM   #2
redmaro
N/A or Turbo?
MK3, Auto, Turbo.
Old 02-21-2007, 01:30 AM   #3
SideWinderGX
o0o, didnt think thered be a difference. 1987 toyota supra turbo, apparently it has a swapped 92 turbo engine with 100k miles on it.
edit: its automatic too.
Old 02-21-2007, 03:07 AM   #4
Red face Maybe more than you want to know
http://www.answers.com/topic/spark-plug
http://en.wikipedia.org/wiki/Spark_plug
http://www.nightrider.com/biketech/s....htm#discussed
http://www.ngksparkplugs.com/techinf...s/techtips.asp
http://www.edelbrock.com/automotive/sparkplugs.html
http://www.centuryperformance.com/spark.asp
Old 02-21-2007, 03:15 AM   #5
SideWinderGX
firstly, thanks for the tips. secondly, id like to verbally rip you apart for just posting a bunch of links to places that have information about spark plugs and not tell me what would be a good choice for a stock\BPU 87 supra....although the information is quite good, im reading it now.
could you throw some links towards me of some good quality and performance, but moderately priced plugs please? id rather not spend over ~200 dollars on 6 plugs, thats kind of a lot lol. thanks for the info again, too.
Old 02-21-2007, 03:32 AM   #6
IHateHacks
IHateHacks's Avatar
If you read those articles they will explain exactly what spark plug heat ranges mean. Its complex and hard to explain with just words, pictures help.
Bottom line, unless you are running 300rwhp you need stock heat range plugs. If you run colder ones, you will foul them out.
NGK iridiums can be found here for $39+ shipping.
Old 02-21-2007, 03:37 AM   #7
SideWinderGX
gotcha. that NGK linnk was the best one. god, its like a worrywarts nightmare :-X in order to get a colder spark plug, youd have to find out the temperature inside the cylinder (inside 500 and 800C is the best)...but how would you find that out? i think i read something about that in the first\second link, but didnt really tell me...basically, octane, compression, gap, plug elements, and timing all come into play, but im not sure how youd choose to go colder a level or two or three.
not saying im going to, but it wouldnt hurt to know
heeeey, thanks for the link. that says 40 bucks for a set of six...so the spark plugs at supraspeed.com arent for one, theyre for 6? haha i thought it was gonna cost me like three paychecks.
Old 02-21-2007, 03:42 AM   #8
We use only Autolite platinum plugs in every vehicle at my shop. Been using them for 30 yrs without a failure.
I have seen lots of failed plugs from Champion, Bosch, and those 'trick' ones.
Most of the techs that I respect (because they are very smart, and many have race cars), won't touch the two brands I mentioned.
Denso may be a good choice. I used them in my race motoX bikes. NGK is also a good choice.
Read those articles, as they discuss going colder plugs per a certain amount of HP increase.
Old 02-21-2007, 03:44 AM   #9
SideWinderGX
i havent heard of those brands, so i probably wouldnt have bought them...but thank you for the heads up.
read the articles, very informative, ill read em over again tomorrow to make sure i remember all the info. i think its for every 75-100 HP you gain, you go down one cold level on your plugs. which i wont have to worry about for a while haha.
NGK iridiums are my first choice, they seem to be really popular and have great results, but ill keep my eyes peeled for any autolite platinums too.
Old 02-21-2007, 03:45 AM   #10
IHateHacks
IHateHacks's Avatar
You'll know the temp inside the combustion chambers by inspecting the spark plug after you've run it. Basically the more power you make the hotter the temps and thats when you go to a colder plug.
It's not something to be worried about with a stock engine. You should be saving your money for all the parts and tools you are going to need for that head gasket, now thats what I'd be worring about.
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
