#41 |
ok well i installled an 89+ bumper onto my supra and i have a question. the directional light connections for the japanese bumper dont mate with the american model ones. is there anyway to bypass/hook up diff plugs to make it work? or even rewire the connection?
![]() nothing but the best -mods- so far K&N intake fipk 3" megan downpipe 3"turbo elbow 4 washers on the wastegate highflow cat short shifter 89+ front bumper, pic soon to come many more upgrades soon |
#42 |
any1? pleaaase
#43 |
shimming the wastegate will add more boost levels, like mine boost gauge is pegged out right now, im doing about 10-11psi on the stock turbo, but if you plan on shimming the wastegate its not recommended to go about 4 washers, although just putting 4 on was a pain in the ass.
![]() 7MGTE - 500hp ![]() exhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
#44 |
hey, i just removed my tps..im gettin my throttle body deep cleened to get all the oil and sh!t out of it...is there a certain way the tps has to go back on, does it need ot be reset or anything?
#45 |
any takers? any1...tps..does it have to be put on a special way or anything?
#46 |
and do i need to apply any gasket sealer to the block b4 applying the mhg?
#47 |
You have to calibrate the TPS when you install it on the throttle body, its in the TSRM.
You have to use RTV where the block meets the inner lower timing belt case, its in the TSRM. The TSRM is your friend. If you don't own one for your year vehicle, call your local dealer and they will tell you how to order one. You really can't do any major mechanical work on this car without the TSRM. |
#48 |
ok well i got it on and all the studs r in place....do i needa remove the cams to put the nuts on the studs? because im not able to get them on
#49 |
I don't know because I used ARP bolts.
Supramacist will know. If I had to guess I'd say no, the cams can stay in place, you are just going to have to use a little ingenuity to get them on, think: pen magnet...... those things are life savers. |
#50 |
If you put the studs in right, you can put an allen wrench on them and pull them 1 at a time. You have to thread the nuts to the studs and drop them throught the washers. Put the washers in place first the place the nut on the stud.
You need a 3/8 drive and a deep well 14mm. If you don't have washers get them. You will have to rotate the cams to get some of them to drop. |
A/C Problem | schutz86 | MKIII Supra | 9 | 07-20-2008 06:08 PM |
Second half of the season begins in Aug… | Guest | Off Topic Forum | 2 | 07-19-2005 10:53 AM |
