Old 02-20-2007, 07:53 AM   #1
drmmr15
drmmr15 is on a distinguished road
Default Steering problems
So I searched around, but did not find anything to really help diagnose my problem. I have an 87 Turbo 5 Speed. I just fixed the car, and have been driving it around. It runs great except for my steering. I know it has a leak, so I have been making sure to keep it full of fluid. But the whining noise has become worse, until finally, I am afraid to drive it because I think Ill ruin something because it sounds so terrible. It is becoming increasingly difficult to turn, esecially when parking. I am going to park the Supra until I resolve this problem. I dont know much about power steering, or about the steering rack, but I was wondering if this sounds like a power steering pump problem, or if I need to replace the whole rack and pinion assembly? Also, is there a specific brand or type of power steering fluid I should be using, or does STP general power steering fluid work fine? Thank you for you advice.
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
Old 02-20-2007, 04:13 PM   #2
supraman121
Is it getting hard to steer? Mine has a crimped power steering hose underneath which in return is wearing out the power steering pump which is what is making the noise
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 02-20-2007, 07:50 PM   #3
drmmr15
OK. I'm going to check all the hoses, and probably replace the pump....once the weather cooperates. Thanks.
1987 Supra Turbo
GReddy TT
Old 02-20-2007, 09:55 PM   #4
yota_head
yota_head is on a distinguished road
i think youre supposed to use dexron II atf in your power steering unit... if you use the wrong fluid it will wreck your pump, and it sounds like its on the way out.
yota_head is offline   Reply With Quote
Old 02-20-2007, 11:24 PM   #5
drmmr15
If I am using the wrong fluid, how do I drain it and put in new fluid? Do I just pull the bottom hose?
1987 Supra Turbo
GReddy TT
Old 02-20-2007, 11:27 PM   #6
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
atf in your power steering pump? isnt there actually power steeing fluid you can buy?
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 02-20-2007, 11:39 PM   #7
yota_head
toyota service manual says use 'dexron or dexron II automatic transmission fluid'
i dont know if power steering fluid is the same stuff, but i would do as the manufacturer says. when you replace your pump make sure you use the proper stuff. these days we're up to dexron III i think, which will fill the requirements of dexron II and I.
Old 02-20-2007, 11:59 PM   #8
drmmr15
Ok thanks. Ill replace the fluid and see if that fixes the problem
1987 Supra Turbo
GReddy TT
Old 02-21-2007, 01:51 AM   #9
volto
volto's Avatar
volto is on a distinguished road
I usually fill mine with Dex III ATF. Slow leak cause my rack and pinion is tearing itself up =/
luckily i have a new one sitting prettily in a box
volto is offline   Reply With Quote
Old 02-21-2007, 02:25 AM   #10
mrnickleye
mrnickleye's Avatar
Unhappy Pump
Dex III is the correct fluid.
Read: http://www.toyota-supra.info/forums/...ead.php?t=3666
Your Likely problem is the pump. Call around for prices.
Kragen's Autoparts....
Cardone Reman 21-5712 List $252
[Power Steering Pump] Remanufactured; Without Reservoir
Limited Lifetime*
Beck/Arnley 108-5069 List $274
Crown 21-5712 List $242
[Power Steering Pump] w/o Reservoir
Reman Rack & Pinion Assembly......
Beck/Arnley 108-1102 List $395
Except Electronic Control Power Steering; Mount Bushings Not Included
Beck/Arnley 108-1101 List $412
problems with my power steering pump pulley... maniakwithpistol MKIII Supra 1 12-05-2008 09:16 PM
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
