Old 03-12-2007, 02:55 AM   #1
adammickeymikey
adammickeymikey is on a distinguished road
Default variable suspension
variable suspension....how hard is it to add to a car that soesn't have it and does it really change that much
adammickeymikey is offline   Reply With Quote
Old 03-12-2007, 05:17 AM   #2
mrnickleye
mrnickleye's Avatar
If mine didn't have the TEMS, I'd not add it. TOO MUCH $$$ and work. It OK, but there are better setups.
I'd get some REALLY GOOD progressive shocks and Eibach (or better) lowering springs.
You'll get a decent ride around town, and have a good curve handling car for speed, and on the mtn roads.
Old 03-13-2007, 05:31 PM   #3
adammickeymikey
good handling on mtn roads at high speeds is what im looking for what else should i replace in my suspension along with that
Old 03-14-2007, 01:16 AM   #4
mrnickleye
mrnickleye's Avatar
Check the ball joints (see the FAQs section), and tie rod ends. They are probably worn out, and are easy for YOU to change.
Look at the other bushings while you are there, cause you'll already have lots of stuff off while doing the springs.
Suspension Chirp? spudz29212MKIII MKIII Supra 5 05-07-2008 02:30 PM
have some questions about 86-92 supra suspension jeremy_e87 Non-Generation Specific Questions 2 01-10-2007 11:53 PM
A/C question - Suspension Q hobbes MKIV Supra 5 06-06-2006 12:04 AM
suspension question mkiiisupra88 MKIII Supra 0 05-25-2006 07:24 PM
clutch - 7mge, and suspension Supro MKIII Supra 2 08-24-2005 03:49 AM
