so i start up the car fine, turn it around and back it into my driveway, so that the nose is facing down my driveway. my driveway is slanted too. get out, blahblahblah, replacing the back speakers and the moulding, remove the taillight bulbs (oh yeah. those back speakers SUCK. the outside rear screws are impossible to get out, it took me 20 minutes with a pair of pliers and a philips head attachment to get it lol. then my 4" speakers barely even fit right.) my dad points out it smells like gas really bad...so looking under the car, we see this:
![]() this above picture is what has leaked onto the ground in about half an hour maybe. it HAS NOT leaked like this when the nose has been higher up than the tail, and didnt leak in the kids driveway. so its only leaking when the tail end is up higher than the nose. ![]() closer pic of the gas tank...it seems to be coming from behind and above the gas tank, and between those two metal flaps. im guessing somethings leaking from higher above, thats filtering down a) between those flaps, and b) behind the tank, coming down and meeting the other gas leak. i could be wrong though. ![]() this is from behind the gas tank. behind the gas tank as in, towards the center of the car. didnt wanna stick it any farther back (stay mature when reading that =P) because gas dripped onto my camera strap and it stinks. overall: what could it possibly be? my dads gonna drop the gas tank sometime soon, after this damn nor'easter goes by and the snows gone again. what would it take to fix, or how much would it cost? thanks for all the info!
my car: 1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it. |
maybe one of the fuel lines attached to the fuel filter. its located right about where the leak is coming from
My cars: 85 Trans Am- Ehhh- Gone 83 Rx7- Much Better- Gone 86.5 Supra- Love- Not Gone |
ill check that out. anything else?
I was thinking the exact same thing, fuel filter lines. One is a 14mm flare nut and the other is a 17mm (might be 15mm can't remember) banjo bolt with 2 copper sealing washers.
Then again, you could have a hole in the top of your gas tank. |
another odd fact: it didnt start yesterday for some reason, but it was super cold and snowing....today it started up on the second try, and right after being shut off it started leaking again. it hasnt leaked at all since last time it was started, and it only leaked for a little bit today. could this be any certain part?
Heater Union (Coolant Leak) | slader99 | MKIII Supra | 11 | 12-28-2009 12:29 AM |
Oil Leak. | supramacist | MKIII Supra | 0 | 05-01-2008 01:18 AM |
Coolant Leak | bossman | MKIII Supra | 2 | 04-12-2008 09:31 PM |
HUGE oil leak | wyosupra | MKIII Supra | 1 | 11-17-2007 10:58 PM |
Oil Leak Question | kidsusukigsxr | Non-Generation Specific Questions | 2 | 06-26-2007 03:17 PM |
