Old 03-25-2007, 08:28 PM   #11
redmaro
LOL, Its located on your turbo elbow.
MK3, Auto, Turbo.
Old 03-25-2007, 08:33 PM   #12
redmaro
Theres a pic or the turbo and where the Oxygen Sensor is located.
MK3, Auto, Turbo.
Old 03-25-2007, 08:39 PM   #13
ethan12510
ethan12510 is on a distinguished road
Okay i have found the o2 sensor but i cant seem to get it off!! Does any one have any idea on how to losen those two bolts? the Bolts dont want to move at all.
ethan12510 is offline   Reply With Quote
Old 03-25-2007, 09:02 PM   #14
redmaro
You found it!!!!
I took off mine with a ratchet and a socket. Maybe you can try and apply some heat to it.
MK3, Auto, Turbo.
Old 03-26-2007, 12:15 AM   #15
ethan12510
Default Stuck?
Well first off where does it plug into? Second i have broken some sockets trying to get it off!!! Third what size socket did you use and does the new o2 sensor come with bolts? Thanks
Old 03-26-2007, 12:52 AM   #16
IHateHacks
IHateHacks's Avatar
It plugs into a yellow connector near the cam sensor.
The 2 nuts holding it on are 12mm.
O2 sensor does not use bolts. There are studs threaded into the O2 sensor housing (turbine elbow) and the O2 is held on by the 2 12mm nuts. And no, a new O2 does not come with any new hardware, just a new gasket.
You better be careful taking those nuts off, if you snap the studs you will be up shits creek without a paddle. In other words, you will need to take the downpipe off and remove the turbine elbow and get a new one or have a shop remove the snapped studs.
Try using a penetrating oil like PB or like he said use heat, a propane torch should do the trick.
Old 03-26-2007, 01:11 AM   #17
ethan12510
well i got one nut off but the other one is really stuck, maybe even stripped? What are my options?
Old 03-26-2007, 01:23 AM   #18
IHateHacks
IHateHacks's Avatar
There are a couple of options. The one that holds the most hope for you is try finding ANY size socket that "almost" fits on the stripped nut but is just barely too small. Then, hammer that bitch on there as hard as you can until it is jambed on the nut. You will ruin the nut and whatever socket you use, but its the only way you will be able to get the leverage to take it off.
But even that method doesn't work 100% of the time. So use this method at your own risk!
Good luck.
Old 03-26-2007, 01:25 AM   #19
ethan12510
okay thanks for that!!! Does any one have a picture of where the o2 sensor connects to becuse i cant seem to find an open connector? Sorry for being such a noob
Old 03-26-2007, 01:32 AM   #20
IHateHacks
IHateHacks's Avatar
Dude, just follow the wire until you get to a big round yellow connector. You really can't miss it.
Unless.......Someone replaced the O2 sensor before and used a universal O2 sensor which requires you to splice it into your wiring harness therefore deleting your big round yellow connectors.
I could post a pic but I worked all day on my pos and I'm too tired to go play photographer right now.
oxygen sensor 82 supra amigo MKII Supra 0 12-13-2008 03:28 PM
Oxygen sensor -wideband or narrowband? azerty MKIII Supra 1 05-06-2008 01:48 PM
oxygen sensor suprakid91 MKIII Supra 3 10-21-2007 04:41 PM
sub oxygen sensor sd88supra MKIII Supra 4 04-13-2007 01:20 PM
Oxygen Sensor questions RyDeFly MKIII Supra 14 02-11-2006 01:41 AM
