Old 03-23-2007, 12:13 AM   #1
Mikek
Mikek is on a distinguished road
Default sick supra
ok guys thanks for the help i burped the radiator and took the car for a test drive and the temp gauge did not move which is ok . but i still get the white smoke from the exhaust and it smell like antifreeze the oil is find not milky i hope its not the headgasket. help what could that be thanks guys .florida.
Mikek is offline   Reply With Quote
Old 03-23-2007, 01:25 AM   #2
IHateHacks
IHateHacks's Avatar
If it smells like antifreeze then it is burning it. Only 2 ways you burn antifreeze, blown head gasket or cracked head.
Sounds like you have a cooling passage to cylinder head gasket leak. Allowing coolant to enter a cylinder but not an oil passage. Same thing happened to me, never had oil and coolant mix.
You can hope all you want, if you want 100% proof, do a block test.
My Supra is sick, please help me! 89_Supra MKIII Supra 3 09-06-2005 01:42 AM
