Old 11-03-2006, 12:41 AM   #1
nickvash0104
nickvash0104 is on a distinguished road
Default Knocking Under Acceleration
Hello everyone,
On my 87 NA Automatic, I'm getting a knock under acceleration. The noise is coming from around the transmission / driveshaft and I'm suspecting a bad u-joint. The engine was replaced in April and I've had no problems since then. Some points to consider:
*It occurs intermittently.
*Usually happens in the 2200-2700 RPM range in drive.
*Does not occur in neutral, reverse, or park.
*All fluids topped off.
*When letting off the gas, it stops instantly and usually does not resume when giving it gas again.
What just confuses me is that it happens intermittently, seemingly without a pattern.
Suggestions?
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
Hard Engine Knocking 86SupraMan MKIII Supra 10 09-14-2007 05:39 AM
funny knocking sound on 7mge Jeff_5_7 MKIII Supra 11 09-09-2007 01:22 AM
Help with knocking on front end supra96 dini_the_owl MKIV Supra 8 09-03-2006 10:24 PM
knocking block, want to build solid bottom, what should i use alcbarrios MKIII Supra 1 04-14-2006 04:16 AM
acceleration problem 91 2 litre supra sexy91tt Non-Generation Specific Questions 2 01-28-2006 09:43 AM
