Question about swapping from a 7MGE to a 1JZGTE
If anyone knows what has to be done to complete a 1JZGTE swap into a 1989 non-turbo Supra PLEASE share your knowledge! I have an aftermarket turbo kit on the 7MGE at the moment and I'm looking to sell it and swap in a 1JZ. The questions I have are:
1)Whether or not the motor mounts from the 7M will match up to the 1JZ? 2)Will the interior wiring harness from the 7MGE match up to the motor harness for the 1JZ? and finally... 3)Will I need to change the cross member if the motor mounts don't match up? |
If it's an 89 you should have no problems. An easy way to tell is if it has round motor mounts its from 89+.
The harness on the 1JZ should hook right up to the interior harness. The only problem is that you'll have to lengthen the harness by about 18". The only reason you'd need to switch a your crossmember is if they are, for some reason, square. But they shouldn't be. And if they are you can just get these. Look for the "1JZ Motor mount adapter brackets." Also if you just buy the engine by itself, you'll also need an R154 transmission. With that change, you'll need an R154 driveshaft, R154 mounts, 1JZ bellhousing, and a 1JZ flywheel. Also to complete the swap you'll need this and this if you are using the hydrofans. There's a few more things but that's most of it. |
Thanks so much for the help, but I just have one more question. If the W-58 transmission will hook up to the 7MGTE and the 7MGE, then does that mean the driveshaft that hooks up to W-58 will also hook up to the R-154? Thanks again for the help...I'm new to the whole world of Toyota motor swaps!
how much
how much do you want to sell the 7m engine for and what kind of modifications to the car did you have to do to turbo the non turbo engine and if you sell the engine are you selling it as a full complete engine with all the accesories i have a 91 non turbo supra and i want a new engine and i want to turbo it and need to know everything that it took to finish it
will the 1jz mount up fine with the 7mgte tranny 5 speed
im looking to do a 7mgte swap into my 86.5. How much for that ecu and harness?
The R154 and the W58 are the same length I checked because they looked different to me when they are on the ground. The W58 will mount up to the back of the 1JZ but you have to change the flywheel and the bellhousing. Cheaper to just keep the R154 and buy a solid driveshaft.
