Old 03-30-2007, 10:12 PM   #1
D_Train
D_Train is on a distinguished road
Default body shop questions
I brought my car into a body shop today because i have some 1/2 inch wide 2-3" long rust spots in my wheel well in 3 of the wheel wells. Probobly three alltogether, one in each well. Anyway, the guy said that I should do something to like, the underside of wheel well to keep it from rotting or something? He mentioned something about them going in through the vent that you see when you open the door or something? Long story short he quoted me $1017.21 and I don't understand everything. What was he talking about with the rotting and the vents and where is the thousand dollars going?
D_Train is offline   Reply With Quote
Old 03-30-2007, 10:16 PM   #2
redmaro
$1,000+ to fix some rust? Seems a little toooooo high.
MK3, Auto, Turbo.
Old 03-30-2007, 11:44 PM   #3
88Tsupra
88Tsupra is on a distinguished road
i suggest going to a different place around 2 more if you go to college go to your school auto shop at ask them..thats what i do for my supra
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 03-31-2007, 02:56 PM   #4
D_Train
but whats the whole "doing stuff to your wheel wells so they don't corrode" business?
Old 04-11-2007, 05:04 PM   #5
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Thumbs up body talk
i think they were talking about undercoating b/c when i weld a patch in where rust was or if i fix a Q pannel then i always use undercoating also known as rubberizer. its cheap stuff prolly 5$ a can all i can think of is that your car is worst off than you can see. but i would go 2 about 2 more shops and get an estimate. w/o telling them the first quote. see where it gets you
Supra_87_mk3 is offline   Reply With Quote
Old 04-11-2007, 06:23 PM   #6
supramacist
supramacist's Avatar
Rust is cancer that never sleeps. If you have holes that big they are going to have to cut it out and weld in new metal so when you ask where the grand is going...., that's about half of it unless you want to drive around with out paint. That would be the other half, body filler, sanding, wet sanding primer, clear coat base coat. Repairing rust sucks.
mk3 supra body differences suprra_girl MKIII FAQ 37 07-17-2009 02:36 AM
Super Duper JDM Shop HIGH END EAST Non-Generation Specific Questions 0 10-14-2007 07:48 PM
Body Kit carfanatic89 MKIII Supra 1 05-21-2007 05:47 AM
body mouldings: questions and concerns NYTRYDR MKIII Supra 7 07-11-2006 06:18 PM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
