Old 04-11-2007, 08:16 AM   #31
west_side_supra
west_side_supra's Avatar
well i tried to clean it got the pistons and got most of the old head gasket off
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-11-2007, 12:41 PM   #32
IHateHacks
IHateHacks's Avatar
Where was this engine sitting prior to you taking it apart? It looks like water filled up a couple of the cylinders. Those rusty cylinder walls do not look good.
What did you use to clean the pistons? I used a whiz wheel on mine but I couldn't get in all the grooves on the pistons. Yours look brand new. But I also used it on the block surface and it took all the old gasket material off and polished it up really good.
Old 04-11-2007, 09:04 PM   #33
west_side_supra
i used one of them wire brush wheels you can put on a power drill. worked great, i used the smaller version of them. yea the engine had been sitting outside in the rain. i mean alot of rain. the engine isnt siezed the main crank turns and the pistons move so im thinking of just haveing it machined cleaned in the cylinders, unless its fine to use the wire brush i mean i dont want to scratch up the walls, if i recall thats a bad thing. the rust is just kinda sitting on there its not a deep rust just a very very light surface type. but ya the pistons i was on it for about 30 mins and made them all look like that its alot better that what it was.
fidenza cam gears
Old 04-11-2007, 09:21 PM   #34
supramacist
supramacist's Avatar
That looks much better. You want to use something with even less grit than 2000. And you want it wet if you are going to do it by hand. I would soak it just like i mentioned in the afore stated post.
So much for TDC. You'll have to relocate it.
Old 04-11-2007, 09:25 PM   #35
west_side_supra
so the items i should probably get for the cleaning process
castrol super stuff
pb blaster
dremel pencil shaver
and high grit paper
oh and a new wire brush because the one im useing is almost finished with.
and what is TDC?
fidenza cam gears
Old 04-12-2007, 01:15 AM   #36
IHateHacks
IHateHacks's Avatar
TDC= Top Dead Center. Its a term used to describe the position of the No.1 piston at the top of it stroke.
But I have no clue what he is talking about, relocating TDC?? You got me......
And using a wire brush on the cylinder walls would be the worst possible thing you could do.
Old 04-12-2007, 04:17 AM   #37
west_side_supra
yea when before i took the head off i placed the crank at zero and lined the markers up for the cams. at least thats what my tsrm told me to do.
fidenza cam gears
Old 04-12-2007, 04:23 AM   #38
supramacist
All I mean is your going to have to turn the crank until pistons 1 and 6 are all the way up top and then we'll probably still have timing issues.
Don't touch any mechanical anything inside the block. Especially the pistons. You make any type of mistake and you'll be ending up with piston slap wich leads to rodknock if not detected and repaired quickley. In any case you'll be rebuilding again basically.
Some of my slangs seem to throw people off. There's a bit of a clutural clash at times. It's nothing we can't work out.
Old 04-12-2007, 10:11 PM   #39
west_side_supra
when i have the crank at 0 pistons 1 and 6 are up as far as they go. so im still lost whey would i relocate it, and how would you relocate it?
fidenza cam gears
Internal motor Question? Rob420 Non-Generation Specific Questions 2 11-26-2006 07:23 PM
Having trouble getting motor separated from tranny... shawn87gta MKIII Supra 15 05-08-2006 05:16 AM
