#1 |
I have a 1987 NON-turbo and I want to put a tubro on it. Whats involved with doing that, do I need to change the ECU, and Injectors? Can my stock clutch handle the extra power? Or should I just sell the car and get a supra with a tubro on it already?
#2 |
Sell the car then find a mk3 with turbo already that's what I did
The only regret that I had was bcuz my na was mint no dents, perfect paint, has one rust spot, for a car from chicago it was pretty clean I wish I could same the same thing for my turbo But the power and the speed change made it all worth the time
http://www.myspace.com/supra_2nr ![]() Into Bikes now,, apparently the supra couldnt kill me, so my zx6 might lol |
#3 |
Going na-t is a pain in the a$$. Do a swap to a 7mgte, especially if your car is clean. It could take months to sell your na.
#4 |
If I switch the motor would I have to change the ECU
#5 |
Yes you do,
If you're really want to convert to a 7mgte Be sure either you have a donor car Or buy a whole front clip Bcuz its the little things that can hold your project for a long time
#6 |
yes and you will need some other parts like ic and other stuff like that
Starter Removal question | OkieRA29 | MKIII Supra | 13 | 05-11-2010 12:08 AM |
Pre89 versus 89+ nose and support. | lifesnotfair | MKIII Supra | 2 | 01-08-2010 09:06 PM |
turbo or not ??? That's the question ... | sausa | MKIV Supra | 7 | 03-30-2007 02:22 AM |
Help! Question on front NOSE and bumper supports. | lifesnotfair | MKIII Supra | 1 | 12-26-2005 03:54 PM |
A few question about 87 tubro supras | BOOST87 | MKIII Supra | 2 | 08-23-2004 08:28 PM |
