Old 04-06-2007, 08:07 PM   #1
west_side_supra
west_side_supra's Avatar
Default code 14 and 52
well hi again everyone, as the subject says i got a code 14 "ignition and ignition coil circute/ignitor and ignition coil/ECU" and code 52 "knock sensor"
could the 14 be setting it off the code 52, say in the case that the coil wasnt working properly and causeing the engine to knock <creating the 52?!?!? if this is the case i have another coil pack
7MGTE - 500hp never dyno'd
fidenza cam gears
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
Code 12 808Supra MKIII Supra 3 05-20-2007 09:55 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
