Old 04-08-2007, 12:03 AM   #1
old dude
old dude is on a distinguished road
Default 1jz supra tight fit turbos
I am starting the task of changing the turbos. This, of course, is a 1jzgte conversion from the 7m engine. I didn't install this engine, but the guy who did put dents in the firewall to get enough clearance for the rear turbo to fit. Now I have to find a way to remove the manifold assembly without removing the air outtake pipe on the rear turbo, which the bolts are almost touching the firewall. Has anyone tried this?Can it be done without pulling the engine? I am trying to get the last stripped bolt off the exhaust pipe and hope to have enough room to get to the exhaust manifold nuts. Wish me luck.
1990 grey Supra 1jzgte conversion
5 speed manual. APEX SAFC. Greddy Profec 2.
HKS blow off. 440 injectors. 3" exhaust. Large Innercooler.
Electric fan. HKS filter and inlet pipe. Greddy Defender
(not installed).Lsd Diff. EIBACH springs. Tokico adjustable struts to TEMS. Ceramic pads on drilled rotors.
Kumho front 225/40 ZR18 rear 265/35ZR18 on AZA wheels
old dude is offline   Reply With Quote
Old 04-08-2007, 02:48 AM   #2
supramacist
supramacist's Avatar
Your'e going to need more than luck. I don't think you can do all of that with the top half of the engine attached. But I haven't worked on your engine, I'm a 7m guy.
Old 04-08-2007, 01:55 PM   #3
old dude
I think the only way to get the back pipe off is to drill a big hole in the fire wall. I should be able to get a socket on it then. Its worth a try
Old 04-08-2007, 03:14 PM   #4
supramacist
You may try a dremel. I know mine has helped me alot and you can get it into places that you can't get to with a drill.
Edit: If you go this route get the pencil grinder attachement.
Old 04-08-2007, 07:44 PM   #5
old dude
I appreciate it. I've got a cheapo dremmel (no pencil attachment) but I may try it anyway. Heading out there now
ANY1 WHO KNOWS SUPRA TURBOS PLEASE HELP!!!!!!& ssupra2005 MKIV Supra 4 08-08-2005 05:32 AM
