#1 |
thank you i'll try tonight after work.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back |
#2 |
ok so i'm a member on HPF.com now but i still cant find a oversized head gasket..i didn't call yet but is there anywhere else i can look?
#3 |
If hpf can't get one you may try there brother company.., titan motor sports.
I'll be surprised if dave can't find you one. You may have to go with less of a head gasket so you can trim it with a razor. But that won't do you any good. Call them man. Hell I'll call him real quick. |
#4 |
Alright he must be busy. Call them and keep calling until he picks up. This guy has gone out of his way for me on some of the parts I have ordered. That forum over there is really slow. I think there are only a handfull of guys using it wich is probably why I come off as such a cowboy. If dave doesn't have it he will find it.
#5 |
Yo...., I spoke to Dave and he says no problem. If he doesn't have your mhg in stock he'll track it down even with you being .50 over. He said he had them in stock from 84 to 86 I think he said.
Dave Nguyen @ ext. 103 |
#6 |
i really appreciate your help with my gasket and i am looking forword to building my car next sat... if i get the gasket in.. i dont know if i should go MHG b/c im not doing alot of boost prolly 15 pounds max until i tune it more.. im still mostly sotck until i fix the HG. Agree Or Dissagree Any Comments would help.
(turbo XS BOV. Intake, cat Back, front strut mount and coil overs.) looking for a boost controler and turbo timer.i would also like to eventualy get a stand alone system but im on a budget as of right now.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back Last edited by Supra_87_mk3; 04-16-2007 at 04:24 PM. Reason: List of mod parts |
#7 |
Wich MHG did you decide upon???
| Thread | Thread Starter | Forum | Replies | Last Post |
| Blown Head Gasket Snake Oil | unkymurch | Non-Generation Specific Questions | 21 | 08-06-2010 02:11 AM |
| 1989 Supra blown head gasket | rayk5799 | Non-Generation Specific Questions | 6 | 05-18-2009 10:51 AM |
| Head Gasket replacement questions. | DavidLeClair584 | MKIII Supra | 1 | 06-09-2007 09:17 PM |
| Buying a 87, head gasket questions | Gengus | MKIII Supra | 1 | 04-14-2007 07:15 PM |
| Head Gasket Part II | Bullz_EyE | MKIII Supra | 2 | 01-26-2006 06:30 PM |
