Old 04-12-2007, 12:49 AM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Default Diff Fluids??
Hey, I need some help on what kind of Diff Fluid I should use. I have LSD and it's a 5 speed. What is GL-4, -5? Can I use Royal Purple Synthetic? What about for my tranny?
abhattan is offline   Reply With Quote
Old 04-12-2007, 01:03 AM   #2
BC_GTE
BC_GTE is on a distinguished road
Correct me if im wrong, GL-4 is 75w-90, GL-5 is 80w-90, Royal Purple is great and your tranny likes it too
BC_GTE is offline   Reply With Quote
Old 04-12-2007, 01:26 AM   #3
IHateHacks
IHateHacks's Avatar
GL-4 and GL-5 are grades of oil 80w-90, 90w are weights/viscositys.
I used 80w-90 GL-5 in my R154 manual trans. That is what the TSRM calls for.
I also used 80w-90 GL-5 in my LSD. TSRM calls for straight 90w GL-5, but lots of luck to you finding that at your local parts store. I know for a fact Redline sells straight 90w fluid but I was too lazy to order it and wait.
Do NOT forget to use LSD additive in your differential. You can get that at any parts store. It comes in little 10oz tubes. Drain the diff, squirt the LSD additive in first, then fill it up with oil.
Royal purple is an excellant choice for oil.
Old 04-12-2007, 05:22 AM   #4
mrnickleye
mrnickleye's Avatar
Talking
I've been using Amsoil racing gear oil in mine for about 4 yrs with no problems. I go ahead and change it every 30k miles, even though they claim 100k miles intervals.
Your only talking about 1 1/2 qts, so it not much $$.
Non Turbo diff vs Turbo diff. abhattan MKIII Supra 0 04-18-2007 11:20 PM
Help..Diff Cont Indicator On (off) / No Speedo Malachiman MKIV Supra 8 03-13-2007 09:25 PM
Rear Diff? supraman121 MKIII Supra 4 11-19-2006 06:47 AM
open end diff. sucks!! 88Supraboy MKIII Supra 2 11-09-2005 08:16 AM
