Old 04-12-2007, 12:44 PM   #1
supradaddy0803
supradaddy0803's Avatar
Default 1JZGTE swap question
I was starting my swap yesterday and noticed a few things when I pulled the engine harness out. There are a few plugs on the harness that don't have a socket under my dash in my 87 N/A. I was wondering if I needed to swap the under dash harness with the swap to make sure all my gauges and bells and whistles on my dash will work. Or do I just need to change out the plugs on the harness to make them fit. Also what is a good boost gauge to used because the gauge on the JDM gauge cluster doesnt swap as well. If pictures are needed of the plugs then I can always get them just wondering from others that have done this swap before. One last question, the fan cooler coil where does it bolt down to and also where does the plug on the end of it go to?
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 04-12-2007, 04:56 PM   #2
supramacist
supramacist's Avatar
I think you will be in need of a 1jz wiring harness. But don't quote me on that.
You may be able to make the 7m work with some wire mods.
Question about swapping from a 7MGE to a 1JZGTE Supraman24 MKIII Supra 13 08-23-2009 10:25 PM
1JZGTE question supradaddy0803 MKIII Supra 6 02-18-2007 07:20 PM
question about motor swap 3000vr4tt MKIII Supra 1 08-10-2006 07:26 PM
1jzgte swap noa324 MKIII Supra 4 03-07-2006 07:24 PM
