Old 04-12-2007, 11:29 PM   #1
supramacist
supramacist's Avatar
Default crank shaft pulley puller
Do I need one of these tools to remove the crank shaft pulleys so I can remove the lower drive belt casing???
I jacked this thing up and the casing is built around the crank. I can get a 21mm 3/4 drive on it but I can't bust that nut and hold the pulleys at the same time and get anywhere, anyway.
Any ideas would be greatly appreciated.
1980 Supra Crank Pulley (Harmonic Balancer) steve6163 Non-Generation Specific Questions 7 06-18-2010 01:47 AM
Crank Pulley Removal go.stfu MKIII Supra 4 07-12-2007 11:16 PM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
Unorthodox Supra Ultra S - Lightened Crank Pulleys Kuban MKIII Supra 1 03-13-2007 09:39 PM
Crank shaft pulley.. MA70_858 Non-Generation Specific Questions 3 07-28-2006 04:47 PM
