Old 04-20-2007, 03:19 AM   #1
supraman121
Default 2.5" drop in front 2" in back?
Does anyone know were i can pick up some 2.5" lowering springs for the front and 2" for the back, im looking for some farly stiff springs, i got kybs struts on the front and im putting bilstein struts for the rear, i want a solid back end.
ALMOST FORGOT SOME GOOD STRUT BRACES FOR THE FRONT AND BACK AS WELL.
Any help would be great.
Thanks in advance.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 04-20-2007, 04:23 AM   #2
supramacist
supramacist's Avatar
www.horsepowerfreaks.com
Speak to Dave at extention 103.
He knows his stuff and he gets it right out of the building and on it's way.
I bought Eibach springs 1.5 in front and 1.0 in the rear. They were here 2 days after I ordered them and I cam currently awaiting a jic rear strut tower rod.
I already have the front.
Old 04-20-2007, 05:49 AM   #3
supraman121
Does anyone know if arospeed is a good company to buy my lowering springs through?, and do you think these are a set of 4, 2, or 1? $129.95 seems a little cheap seeing as how the eibach springs 1.6" drop front and back are $230.00?
K&N Air Filter
Old 04-20-2007, 06:08 AM   #4
supramacist
What I do know is that Eibach is one of the leading manufacturers of springs.
From what I have read they sell more springs globally than any other brand.
Old 04-21-2007, 06:46 AM   #5
I've looked far and wide for springs with more drop than the eibach, 1.6 & 1.0. None so far.
Old 04-21-2007, 03:11 PM   #6
redmaro
Some guy was replacing his stock springs with some Eibach springs from checkers which were suppose to lower the car 1". After looking at his stock springs and looking at the Eibach springs he should of stayed with his stock springs, they looked way more stiffer than the Eibach springs. IMO I wouldnt buy those Eibach springs they look weak, their deffintly not stronger than the stock ones on the supra.
MK3, Auto, Turbo.
Old 04-21-2007, 08:38 PM   #7
supramacist
You are the only person I have heard say anything negative about Eibach.
They aren't supposed to be the same gauge as the stock springs. There is less spring in a good way. I just don't happen to have the words or the time to explain it.
But your'e the first.
Old 04-22-2007, 07:07 PM   #8
Wink Looks ???????
Sooooo......you base your opinion entirely on LOOKS.
I had an 18 year old girlfriend once that was a Playboy magazine candidate. This girl was sooo good LOOKING.
But LOOKS were deceiving, as she was a bit loony, which is why she did not get into the magazine.
Here's what works for me.
Research, analyse, learn,..... works every time.
http://www.streetfire.net/2007/03/st...of-eibach.aspx
http://www.cardomain.com/features/peopleschoice
http://eibach.com/eibach/news/img/F1championlist06.pdf
http://eibach.com/cgi-bin/htmlos.exe...29679200030487
Old 04-23-2007, 03:21 PM   #9
supra_91
supra_91's Avatar
if you want a 2.0"+ drop then you should get the bilstein struts since i think they have an adjustable perch
Old 04-23-2007, 04:17 PM   #10
redmaro
I still wouldnt buy them, you can almost compress them with your hands. LOL
MK3, Auto, Turbo.
front coil spring... hangsupra MKIII Supra 6 06-03-2007 09:25 PM
