Can anyone send me picture or a web site where I can see Vacuum Diagram for 1987 7gte supra engine I just pulled the motor out of the car and im having trouble hooking it all back up.
thanks |
#2 | |
![]() Quote:
http://www.toyota-supra.info/forums/...ead.php?t=8072 IT says........ Check the FAQs Section First........ Be sure to do it. There are several threads on important subjects that everyone ALWAYS asks about (every month). Did you do a 'search'. type the words...vacuum diagram. I hate sound so cruel, but, to bad !
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. Last edited by mrnickleye; 04-22-2007 at 07:26 PM. |
I went to that site and it shows where they go, but I need pics b/c there are brackets that the hoses go to and i dont remeber were to bolt the brackets up. I should have tooken pics before, but I didn't. If someone could send me a pic of the left hand side of the car where the brackets and hoses go it would help me alot.
Thanks |
ha this isnt gonna help you but i had the same problem, luckly i was replacing my hoses and was about to cut them and relized i can just skip the pipe and run hose. good luck with your build though
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
OH ! Yep, putting the brackets back in their original place can be a real headache.
Seems like you would need a big mirror to take photos up under the intake manifold. I just looked, and felt, around and found places that seemed to work OK. And, like he said above, you can always run longer hose, use zipties, etc.
#6 |
Heck, I did the same bone head move when I did my BHG.
Lucky for me I live near Mrnicleye and he saved my butt : ) I even had pictures but I did not get under the manifold as stated.
89 N/A Supra Previous: 90 Turbo 86.5 N/A 85 GT http://s81.photobucket.com/albums/j2...%20For%20Sale/ |
#7 |
Hey, you're not alone. I replaced the motor in my 87 N/A with a JDM 7MGE, and I have to go back and reconnect all the vacuum lines. Let me know if you find a really good diagram.
Vacuum hose | suprabahamut | MKIII Supra | 10 | 01-08-2009 12:52 AM |
really could use help - vacuum, race on the 26th | carl johansson | MKIII Supra | 2 | 12-24-2007 11:37 PM |
Vacuum Hoses and Diagrams | kewlcoconut | MKIII FAQ | 11 | 08-13-2007 01:41 AM |
Newbee: Question About Vacuum lines.. | Alejo_NIN | MKIII Supra | 3 | 01-12-2006 07:18 AM |
vacuum advance/retard | tonster | MKII Supra | 0 | 09-16-2005 06:43 PM |
