Old 04-23-2007, 03:20 AM   #1
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
Default bad sounds
ok so i was driving my 1988 supra last night and i started fellin some funny vibrations from the front left tire and stuff so i took the tire off and cheack to make sure it was on good and it was os i put it all back ot gether and dont it makes a funny squaeking and and virbrates really bad like it makes the sterring wheel shake whats wrong im sure it has sumthign to do with the suespision
Supras anrt ricers there Japanese Muscle
1988 supra n/a just finsihed 5 speed swap
goal is 400hp with a turbo motor swap
Jeff_5_7 is offline   Reply With Quote
Old 04-23-2007, 04:49 AM   #2
supramacist
supramacist's Avatar
Sounds like you could need a front end alignment. Maybe tire rotation and mount and balance.
Old 04-23-2007, 05:39 PM   #3
west_side_supra
west_side_supra's Avatar
check inflation, wear marks, look at the tires for any bulges like a hudge zit. sometimes there small. and also push down on the car set your tems for normal and push it down, if it bounces more than 2 1/2 to 3 times you should look into getting new shocks. otherwise a good balnceing or alignment, if your really unlucky its the joints.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-24-2007, 05:53 AM   #4
mrnickleye
mrnickleye's Avatar
If you really can't see or find anything wrong, put that tire on the rear and test drive to see if things change (to the rear).
weird sounds when car moves Donovan MKIII Supra 10 06-08-2007 11:14 PM
supra problems weird sounds please help Donovan MKIII Supra 13 05-12-2007 06:34 AM
Bov Sounds!!!!!!!! justin1642 MKIII Supra 6 09-18-2006 04:58 PM
mk3 supra NA vs. Mitsubishi 3000GT NA stealth06 MKIII Supra 48 08-02-2006 04:39 AM
Car sounds like CRAP! PsychoDad MKIII Supra 2 05-30-2006 11:06 AM
