Old 04-25-2007, 12:08 AM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Default Boost Issues
Wassup everyone! I seem to be having some issues with my boost. I shimmed the wastegate on Sunday and the boost didn't go up to 10lbs. I shimmed it about .25 inches. But the boost response was better. Then the next day, trying to get out of some traffic, it shot up to 10lbs. Then later that day it struggled to go to 10 lbs. Later that night I ran out 2nd gear and it got to 9lbs and went up and down to 7lbs. Then 2 minutes later, I ran it out again and it went all the way to 10lbs and held and then through third it held. Today I checked for vacuum leaks and found nothing. However, there was some shaftplay in the turbo from side to side, none in and out. Maybe a couple of sixteenths. Do you think that might be it? And will my head gasket hold up to 10 lbs?
abhattan is offline   Reply With Quote
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
