Old 04-27-2007, 05:53 PM   #1
redmaro
Default Changing LSD oil.
Im changing the differential oil, but I have a few questions. The hayness maunual says to go with 90W GL-5 limited slip gear oil. Is that what I should be using? And I was thinking of getting royal purple gear oil btw. I also heard about adding some kind of addivtive to the diff. Thanks.
MK3, Auto, Turbo.
Old 04-27-2007, 08:25 PM   #2
west_side_supra
west_side_supra's Avatar
i dont know but while your down there you should weld up the diff's so you can have POSI its a hard one to pull off but if you get it welded really good then can drive the piss outa it without the welds breaking.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-27-2007, 08:47 PM   #3
supramacist
supramacist's Avatar
People still weld those for that??? I thought they stopped doing that in the early 90's. Aren't there some spider gears that you can replace and have full positraction?
Old 04-27-2007, 11:21 PM   #4
west_side_supra
i dont know i just hang out with alot of them toyota 4x4 guys who like to go rock cralling and we just weld them up and call it good.
fidenza cam gears
Old 04-27-2007, 11:30 PM   #5
kwnate
SP58GT
He has a turbo, therefore he has an LSD (Posi trac). Welding it would make it a mother f'er to drive around parking lots...
You can use Royal purple 90w, just make sure its made for lsd's. It should say.
Nate
Old 04-28-2007, 02:35 AM   #6
redmaro
Aliright I get the 90w LSD oil. Thanks
MK3, Auto, Turbo.
Old 04-28-2007, 02:39 AM   #7
redmaro
Yeah I would deffinetly not weld the diff, I want my car to be able to make turns. LOL
MK3, Auto, Turbo.
Old 04-28-2007, 09:16 AM   #8
west_side_supra
yea thats where i differ, i like my car sideways on the turns
fidenza cam gears
Old 04-28-2007, 11:13 PM   #9
1J 2J
1J 2J is on a distinguished road
Thumbs up Lucas Oil
Lucas Oil I Been Using It In My Diff And It Works Amazing .give It A Try
1J 2J is offline   Reply With Quote
changing fuel filter 3.0trd MKIII Supra 9 04-22-2008 10:47 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
changing out ring gear Burn N' Up MKIII Supra 0 08-30-2006 07:09 PM
Changing BHG?! TxSpeedBoy Non-Generation Specific Questions 7 01-17-2006 08:49 AM
Changing stock air intake. lifesnotfair Non-Generation Specific Questions 7 01-02-2006 08:50 AM
