Old 04-27-2007, 08:20 PM   #1
D_Train
Default new engine question
I had a new engine put in by the dealership 30k miles ago. Now i am showing signs of a BHG and i BABY that car since the engine blew the first time. what gives?
Old 04-27-2007, 08:26 PM   #2
west_side_supra
west_side_supra's Avatar
well since you got it from the dealership it may have a warrenty. id check that out, otherwise go to toyota and bitch them out for putting a shitty head gasket in it hehe.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-27-2007, 08:41 PM   #3
supramacist
supramacist's Avatar
Also sinse you got it done at the stealership those head bolts won't be torqued tight enough if you relied on them to do it because the tech book or tsrm still says 59lbs of torque, So I would look into the head bolts with a torque wrench and your trusty 14.mm socket.
I tried everywhere today to find a deep well 14.mm 12 point socket for my stud bolts. What a task not a parts store in town had one. I ended up getting it at sears.
Old 04-28-2007, 12:36 AM   #4
j3pz
how does such a great company like toyota fuck up something like this...again? im sure they no about this problem and how to fix it... /rant
id go back and bitch them. it wont make you feel better but after you leave you can laugh that you just made someone as miserable as you.
Old 04-28-2007, 03:14 AM   #5
D_Train
I work in customer service so i can be good at making people feel miserably for shoddy service. So the consensus is that I have a right to go and bitch them out for a BHG after 30k miles?
Old 04-29-2007, 02:57 PM   #6
j3pz
well ask them what they torqued the head to. tsrm says 50ft/lb i believe but it should be more like 75-80
88 Supra.. body work and engine question - quickies : ) Grandavi MKIII Supra 5 10-08-2010 04:58 AM
1983 supra engine question 101jinx101 MKII Supra 0 12-06-2007 10:47 AM
Engine Harness question kidsusukigsxr Non-Generation Specific Questions 0 01-31-2007 05:33 AM
Engine build question... 2JZEFINI-17 MKIII Supra 2 01-04-2007 10:29 PM
Question about Slick 50 engine protection! 88 MARK3 Non-Generation Specific Questions 15 07-15-2006 04:04 PM
